Gas tank strap padding
Old Jul 21, 2010 | 07:44 PM
evam350's Avatar
evam350
I bought a new fuel tank and new lower straps for my 73 because the old tank was worn through at one of the straps, patched poorly and leaking.
The old straps had some sort of rubber on them (most of which was deteriorated)
Does anyone know where I could buy this stuff?, because my new straps don't have it or is it not neccesary?
Also is there any place to buy new upper straps?
Old Jul 21, 2010 | 07:56 PM
mikeo0o0o0's Avatar
mikeo0o0o0
I used the same material that is used to retain the door glass in the door glass retainer.
It's available from LMC. P/N 49-9300 $12.95. One is more than enough to do both straps, plus one side is sticky so it makes it easy to install.
Old Jul 22, 2010 | 06:35 PM
dynamic's Avatar
dynamic
I ended up using some rubber strips from toolbox mounting kits that I had laying around at work. Material was around 1/8" thick by around 3" wide.
Sometimes you just need to be creative!
Old Jul 22, 2010 | 07:33 PM
hp246's Avatar
hp246
I made mine out of an inner tube.
Old Jul 22, 2010 | 07:48 PM
benmoderow's Avatar
benmoderow
I used peices of an old ratchet strap, not rubber but will still protect the tank
Old Jul 23, 2010 | 08:55 AM
4wydnr's Avatar
4wydnr
I used some old seat belts.
customxl
1997 - 2003 F150
66
Jun 14, 2019 07:45 AM
rdpickett406
1978 - 1996 Big Bronco
Apr 25, 2017 05:43 PM
schmiddw
Dec 7, 2015 08:39 PM
Gertie-The '49 F2
Nov 9, 2015 05:44 PM
94MustangGT
Aug 20, 2015 10:58 PM
