Rattling Door Check Straps
As the title says.
Driver door isn't bad, but the passenger used to rattle horribly, to the point it was drowning out all the other rattles, squeaks, pops, and groans. Applied a big wad of electrical tape to where the rubber bumper used to be at one point, and was able to get it to quiet some.
Then I noticed Carpenter's were offering re-popped straps, so I bought two. Was very pleased, as they looked exactly like the originals. Really only needed the bumpers, but installed the entire strap, as they are nickel plated and look better. Re-used the old pins because the new ones didn't look like the old ones.
While the rattle is certainly tolerable now, it is still there occasionally.
I noted that, when installing the new straps, there appears to have once been something installed along the inner face of the door edge where the slot is for the strap. There are two rivets, one above, and one below, the strap slot. I suspect that when new, there was once a thick rubber piece attached to the door by those rivets, and that it had a slit that the strap slid through, and maintained tension so that the strap didn't flop against the opening.
I have come to the conclusion that the easiest fix, is to cut a rectangular piece of relatively dense rubber, perhaps 3/8" thick, and glue it to where the old piece used to reside. I see no easy way to re-rivet a new piece in, as there just isn't much room to get my fat paws in there.
Anyone here address this issue in their trucks?
I have also thought it may be possible to get a rivet gun down inside the door, but if that is possible, I still would have to contend with the issue of trying to get the old rivets out. Just ain't no room down inside there. They just about had to put that rubber piece in before the door skin was put on.
Won't be looking at it tonight though, drizzling rain and cold out there. Dark too. And really wet.
Mearntain
15
09-13-2020 08:40 AM
jhaas63
07-29-2014 08:37 AM
joditruck
16
02-23-2008 10:39 PM
scottddove
12-23-2006 06:56 AM
