Please Identify this fuel line.
Old Jul 20, 2010 | 11:34 AM
eautiger's Avatar
eautiger
Question Please Identify this fuel line.
Attaches to the fuel outlets. Lower and to the rear of the right side of the housing if I am not mistaken.
What on earth is this line called? I believe mine is cracked or leaking. Drains off of the V in this line.
Anyone ever see it develop a leak enough to fill the rear depression in the valley and out the drain hole? It is just pouring out and truck kerplunks, no knocking, just kerplunking and fuel streaming of the drain hole and out the drip pan below.
You guys are a great help.
Also, I replaced the turbocharger o-rings and may have bumped the line. Very possible.
Part Number?
Old Jul 20, 2010 | 11:50 AM
Izzy351's Avatar
Izzy351
Those are the fuel lines feeding the heads. One goes to each head, and yes, they are known to develop leaks, usually around where the hold-down is...
Old Jul 20, 2010 | 12:09 PM
eautiger's Avatar
eautiger
You are a good man.
Old Jul 20, 2010 | 12:20 PM
tdpower's Avatar
tdpower
This should be the part number: F81Z-9B273-BN
I would still verify that is correct. Found it in this thread: https://www.ford-trucks.com/forums/8...aakkkkkkk.html
Old Jul 20, 2010 | 12:22 PM
Izzy351's Avatar
Izzy351
Also, what year is your truck? There was a difference in the lines on some of the earlier SuperDuties (maybe early 99 only?). Those can rub near the fuel bowl somewhere and develop leaks there, too. I can't remember the exact details, but I remember seeing a thread about it on here recently.
Old Jul 20, 2010 | 01:12 PM
eautiger's Avatar
eautiger
Just picked up the part. How tight do the fittings need to be? And what about primiing before starting?
eautiger's Avatar
eautiger
2002 is the model year.
Old Jul 20, 2010 | 04:03 PM
CSIPSD's Avatar
CSIPSD
Electric fuel system... Turn the key... wait... turn the key... wait... turn the key and start.
tight, just snug and check for leaks.
Old Jul 20, 2010 | 04:23 PM
eautiger's Avatar
eautiger
Runs as if a cylinder is missing. No power at all, shudders with throttle.
Still air in fuel lines?
Old Jul 20, 2010 | 04:33 PM
CSIPSD's Avatar
CSIPSD
How long has it been running? It does take a few minutes to clean out the air, but no more then 5-10 minutes.
Old Jul 20, 2010 | 04:47 PM
eautiger's Avatar
eautiger
She's running fine.
Old Jul 20, 2010 | 05:33 PM
CSIPSD's Avatar
CSIPSD
Good deal!
Old Jul 20, 2010 | 06:50 PM
Kwikkordead's Avatar
Kwikkordead
Couldn't have said it better myself.
Couldn't rep you for it either, rep police are on patrol.
mary-kate
37
Mar 9, 2018 11:00 AM
crazyredneckanyhow
Ford Truck Parts for Sale
Apr 16, 2017 02:31 AM
izzo
Sep 27, 2015 11:53 PM
down2earth
36
Sep 6, 2015 01:35 PM
Shadowrider123
May 30, 2015 09:41 PM
