Weird smoke issues
Old Jul 20, 2010 | 08:53 AM
Action4478's Avatar
Action4478
Cups fail most likely fuel in the coolant, head gasket would be more pronounced in the AM at startup & may have a miss ..
Bill may be on to something If that is not the case ,then
I might be leaning toward a nozzle spring or a nozzle problem .You said the injectors are new . How new ?
Old Jul 20, 2010 | 08:55 AM
DZL JIM's Avatar
DZL JIM
PREMIUM SPONSOR
Hmmm...Not sure how the IDM would do that, but if this came up the same time the IDM was done...
Cups failing would push fuel into the cooling system and overflow the coolant.
Bad o-rings would push oil into the fuel so fuel filter would be black. Cahnge filter, run the truck for a bit, then cehcek fuel/filter again.
Injectors are fairly fresh so it's unlikely it's an o-ring, but anything can happen when William get's buzzed up before working on his truck.
__________________
'96 7.3 F-350 Reg Cab 4x4 - bought new.
'04 6.0 E-350 custom 4x4
'08 6.4 F-550 Reg Cab 6 spd 4x4
'17 6.7 F-250 KR ccsb 4x4
Old Jul 20, 2010 | 09:02 AM
Action4478's Avatar
Action4478
Originally Posted by MADVAN
Its it a greyish haze of smoke?
You can see the haze more at night from the cars behined you. (headlamps)
Try it in other tunes. Note the changes if any.
Iam betting that you are over fueling with the idm mod.
The grey is unburnt fuel while the black is not completely burned fuel.
Bill
Might T have a spare IDM to test with ?..
Old Jul 20, 2010 | 09:05 AM
jchosler's Avatar
jchosler
I dont have the IDM mod and I have the same issue. My injectors have maybe 3k on them and my fuel filter looks a little dirty but not black
Old Jul 20, 2010 | 09:17 AM
MADVAN's Avatar
MADVAN
The idm mod will advance and add fuel.
This is on top (added) of the chip he has.
Bill
Old Jul 20, 2010 | 09:22 AM
Talyn's Avatar
Talyn
Got a wet tail pipe after we talked rick.
Stopped and now I'm idling whitte smoke.
Doesn't smell like fuel or oil.
Truck was at operating temp. 203
MADVAN's Avatar
MADVAN
Rick
Its not an issue with the idm in itself.
A tell tail sign is just change the chip setting or remove
the chip ect. If the smoke change with it you know its
the tune. It has alot to do with motor condition. How
efficient the burn is in that exact motor.
This all on a wag on his truck as of now.
Bill
Old Jul 20, 2010 | 09:26 AM
MADVAN's Avatar
MADVAN
Not good.
Now my input on the issue has changed.
Have you noticed coolant level drop?
Using syn oil?
Pressure test the cooling system. If it passes the test
you might be going back into the turbo.
Bill
Old Jul 20, 2010 | 09:31 AM
Action4478's Avatar
Action4478
Not good.
Using syn oil?
Bill
He has a leaking Rad & can't pressurize the system yet...
DZL JIM's Avatar
DZL JIM
PREMIUM SPONSOR
I've never ehard of a few mroe volts from teh IDM casuign any issue like that, i doubt that's it.
My next thought would be turbo seals gone and it's actually oil causing the smoke.
Happened to me once a few years ago.
__________________
Old Jul 20, 2010 | 09:34 AM
Action4478's Avatar
Action4478
One more thing T said on the phone , it started the last time he topped off the coolant..
Old Jul 20, 2010 | 09:38 AM
jchosler's Avatar
jchosler
Is there any way to tell if the seals have failed?
Old Jul 20, 2010 | 09:47 AM
  #28
MADVAN's Avatar
MADVAN
Not good.
A tread goes way out of wack when you dont get the full story.
Depending on how low it got along with how hot it could have
developed a crack. Most times it will be a cup. A sign is fuel
in the coolant will be seen.
This is all wags from me. A pressure test of the cooling system is needed first.
Then move on to the next if passed.
Bill
Old Jul 20, 2010 | 09:54 AM
  #29
MADVAN's Avatar
MADVAN
X2 jim.
With the use of syn oil its much different. Most of them
do not want to burn. Had a motor with a bad exhaust valve seal.
The oil made it all the way to the end of the tail pipe!(dripping)
Bill
Old Jul 20, 2010 | 02:37 PM
  #30
Talyn's Avatar
Talyn
Ill post more when I get home. Phone is being a pain. Won't let me watch what I type.
Coolant is good. No fuel in there. Level in res has dropped an inch or 2
Leak is slow where it is. So its not from that.
Its not fuel in tailpipe. Def coolant smelling. Pure white. Tint on glass makes it look blue in mirrior.
Uhm. Havnt checked fuel color yet. Don't want to get fuel all over this guys yard. Working today.
Uhmm, bill. Settings on chip making no difference either. First thing I checked. Just turns into black smoke with higher settings. Smoke setting even puts out white first.
High idle does same. That's just a stock tune with higher idle. White smoke therre. Getting rid of this smoke tune next burn. Worthless.
