MAP...Boost...I don't know...
Old Jul 20, 2010 | 06:06 PM
cheezit's Avatar
cheezit
Originally Posted by cartmanea
Sorry for the hijack, but the people who know have just been chiming in.
I bought a second spare PCM with VXAN0 or VXAM0 strategy (early '03). I ran this briefly to make sure it worked and everything seemed fine, no codes and truck had the aggressive tow/haul back (original pcm has 06E17 recall flash). So the PCM does contain VIN and build data other than just 6L/Auto? I've been thinking about running the other PCM full time, but this makes me think otherwise.
you should be fine.
Old Jul 20, 2010 | 06:10 PM
cartmanea's Avatar
cartmanea
Thanks cheezit, so are you saying the pcm data is generic between all the 6L/Auto trucks of the same year and strategy, or that it does contain VIN and other data but running it won't hurt anything?
Thanks again!
Old Jul 20, 2010 | 06:13 PM
cheezit's Avatar
cheezit
it shoudl have a vin in it. but the pcm is somewhat generic with info. I have aba swaped a few for testing and the worst I have got was a vid mismatch error but everything works
Old Jul 20, 2010 | 06:17 PM
cartmanea's Avatar
cartmanea
Sounds good, thanks again!
Old Jul 22, 2010 | 01:02 AM
Gmcbuffalo's Avatar
Gmcbuffalo
I am very pleased with my Insight CTS. Today while looking for Cheezit's MPG PID I saw Turbo Boost hit enter and took it for a run and I am getting Boost pressures anywhere between 6 and 18 with normal driving. I also have EOT, ECT and TFT. The only short coming is the display has no color except in analog function. I monitor ECT, EOT, TFT, EGT and Turbo Boost. What do you think are the most important numbers to read?
I have 2005 PS Excursion
Old Jul 22, 2010 | 01:31 AM
cartmanea's Avatar
cartmanea
What do you mean by that?
Old Jul 22, 2010 | 10:33 AM
chrischaugen's Avatar
chrischaugen
He means that if you select to monitor more than 3 PIDS, the background will go to black, and the screen will split into X amount of squares, depending on how many PIDS you want to monitor. If you select Analog, the background is customizable, and with color. The downfall to analog is you can only monitor 3 PID's.
Old Jul 22, 2010 | 10:37 AM
cartmanea's Avatar
cartmanea
Is analog a display mode though or does the device gather data differently? Is it just an analog gauge readout instead of digits?
Old Jul 22, 2010 | 10:44 AM
chrischaugen
Yes, analog is a display mode. If you look on the Edge website at the CS/CTS, you'll see the analog screen. There are digits, along with 2 analog 'gauges'. You can select what PID's you want to see with the analog gauges, and then there is a digit only monitor on the bottom middle of the analog gauges.
If you choose to monitor more than 3 PID's, there are only digits...
I hope that answers your question.
Old Jul 22, 2010 | 11:02 AM
cartmanea's Avatar
cartmanea
Yes it does, thank you.
Old Jul 22, 2010 | 11:35 AM
Striderwv's Avatar
Striderwv
Does anyone have the cs or cts hooked up to a 2004.5 (two boot cac)? What parameters are you able to monitor? Thanks. Doug
LDP
13
Jun 16, 2012 10:00 AM
funzjb1
13
Feb 16, 2010 08:55 AM
Packard V8
Sep 16, 2009 05:29 PM
travis dasher
33
Mar 21, 2007 06:39 AM
me235
Feb 18, 2007 09:28 PM
