boost question
Old Jun 14, 2012 | 11:15 PM
LDP's Avatar
LDP
boost question
I have a 1996 f-250 all stock except down pipe and the 6673 filter. I think i might have a boost problem when i am driving on the highway unloaded my boost is 2psi and sometimes just under is that a normal boost on these trucks or low? Even unloaded on a hill it will smoke a little black and towing it smokes black just a little even on flat. I unplugged the sensor and i dont see any change in the psi its still reads 2 psi down the highway.
Old Jun 14, 2012 | 11:20 PM
BuckHammer's Avatar
BuckHammer
Mine's pretty much stock and never smokes black. Even when it was bone stock it didn't smoke black.
Old Jun 14, 2012 | 11:56 PM
1dieselman's Avatar
1dieselman
If your truck is all stock you won't build any significant boost until over 2200 rpm's and the max should be about 16-17 psi and you will need to run some pretty high rpm's to see that.
Old Jun 15, 2012 | 12:05 PM
RÖENTGEEP's Avatar
RÖENTGEEP
FOREIGN GURU
Lightbulb
And with some load.
Old Jun 15, 2012 | 12:44 PM
LDP's Avatar
LDP
I have hauled 8000lb trailers to 16,000lb trailers and i dont remember ever getting over 10 psi.
Old Jun 15, 2012 | 01:02 PM
1dieselman's Avatar
1dieselman
You need to start looking for exhaust leaks, problem with your turbo, or maybe a intake plenum boot is tore. Also possible that the o ring between the turbo and intake Y is broken.
Old Jun 15, 2012 | 01:09 PM
LDP's Avatar
LDP
Thats what i have been thinking just wanted to make sure it was on the low side before digging to much. I think my injector o rings are going as well.
Old Jun 15, 2012 | 02:25 PM
RÖENTGEEP's Avatar
RÖENTGEEP
FOREIGN GURU
Exclamation
Well if that is the case, yes your boost is very low. Follow what Jack said above.
Old Jun 16, 2012 | 12:47 AM
oldbird1965's Avatar
oldbird1965
X3 on what Jack said! Stock I was only hitting 15psi.
Old Jun 16, 2012 | 07:46 AM
Redneckmorton's Avatar
Redneckmorton
What's the best way to look for leaks on both sides?
Old Jun 16, 2012 | 08:12 AM
91 Dually's Avatar
91 Dually
You unplugged the sensor and it still reads 2 pounds? Sounds like you need to check your gauge and how is it hooked up?
Old Jun 16, 2012 | 08:48 AM
1dieselman's Avatar
1dieselman
The exhaust side look for formations of soot around the exhaust manifolds, uppipes, and collector gasket. The pressure side pull the intake Y and inspect the o-ring and boots going to to plenums.
He said he has see 10 psi with a heavy load so didn't really feel that it was the gauge but anything is possible.
Old Jun 16, 2012 | 09:57 AM
LDP's Avatar
LDP
I put a t fitting in the map hose to the sensor for the gauge.
Old Jun 16, 2012 | 10:00 AM
oldbird1965
That's good, did you blow thru the lines to make sure they are clear?
Tdracer344
Aug 15, 2016 05:31 AM
ranagent
Aug 29, 2015 07:58 AM
jleal_21
Apr 11, 2010 08:25 AM
Excursionator
Jul 21, 2009 07:49 AM
scalezy3b811
Lightning, Harley-Davidson F-150, Roush F-150 & Saleen F-150
Dec 21, 2004 01:54 PM
