dsII ballast resistor
Old Jul 17, 2010 | 03:09 PM
fordnewbie42's Avatar
fordnewbie42
I have a 83 f150 302 tha needs the resistor wire. I have searched, but cannot find one or a replacement. truck runs fine with 12v straight to coil.
Is this bad for other components? If so will a dodge ballast work or what should I do? Thanks for any advise!
Old Jul 17, 2010 | 04:20 PM
81-F-150-Explorer's Avatar
81-F-150-Explorer
Go to Ford dealer parts department and ask them for a balast resistor, or go to your local autopart stores and get one from them. Explain to them what it does if they don't understand.
Running the full 12V to the coil will burn it up eventually.
Old Jul 17, 2010 | 04:37 PM
fordnewbie42
The dealer calls for a resistor wire #D7AZ 12250 A which is obsolete. I should have said that first. Thats why Ithought of the ceramic resistor. Thanks
Old Jul 17, 2010 | 05:23 PM
81-F-150-Explorer
Fits 1977-1986 F-series, Bronco, Econoline with DS-II.
These trucks and vans also had this resistor with EFI in the wiring But it wasn't used.
Wrecking Yard should also have it also. Just cut it right at the splices at both ends. Do not make it any shorter.
Places like Napa auto should also have it. But may have to order it.
Fuse links and ballast resistors are unknown to most parts people anymore, but someone should carry it.
Old Jul 17, 2010 | 09:05 PM
Franklin2's Avatar
Franklin2
I would try one from a Chrysler. It needs to be in the neighborhood of 1 ohm resistance to work. And mount it clear of anything that could catch fire, it does get hot.
Old Jul 17, 2010 | 10:50 PM
roadrash63's Avatar
roadrash63
Originally Posted by 81-F-150-Explorer
Fits F-series, Bronco, Econoline with DS-II.
hey
what color is the wire on efi harness...
I'm going to carbed mtr ...
ty
Old Jul 18, 2010 | 03:44 AM
81-F-150-Explorer
It's Red/Light green. You should already have the DS-II power plug in the main harness in the engine compartment.
This is because the ballast resistor is in the main harness.
What you should be able to do is get a DS-II engine harness, unplug your TFI-IV harness and plug the new DS-II harness in it's place. Lariat 1985 has already done this swap with great success. Although he had a carbed motor, he still had TFI-IV, EEC-IV like you have.
Hope this helps...
Old Jul 18, 2010 | 07:45 AM
roadrash63's Avatar
roadrash63
ok ty
I'm going to beusing points.
and want get rid of eec
ty
Old Jul 18, 2010 | 11:16 AM
81-F-150-Explorer
The ballast resistor for a points vehicle has a different resistance and ohm factor than the one with DS-II. I do not know how much that matters, but from my service books there is a difference to them.
The spark is also weaker with the points system and requires different spark plugs and gap, (closer gap) than the DS-II/EFI systems. So the adjustments on the current emissions lable wouldn't work well for you. Use the adjustment settings and spark plug gap for a 1973 302 for example for best results.
DS-II is more reliable than points/Condenser systems in my opinion, but that's just an opinion.
Old Jul 18, 2010 | 01:04 PM
roadrash63's Avatar
roadrash63
ok thanks for the info
Old Jul 18, 2010 | 10:03 PM
fordnewbie42
Thanks guys I found my problems. Sometime before someone else cut the tape off the harness, and guess what. There were at least 8 slices in the resistor wire alone! It overheated and melted a few with it.
The first factory splice is near the module and the other end is behind the instrument cluster upper left hand corner. Not a simple cut and splice.
I used the AC Delco #C1101 resistor and mounted it on the left fender tab under the hood hinge.
It's not perfect, there is 9.5v at the coil, but accel makes an adjustable resistor that should do the job better. That will be for when I have more time.
THANK YOU 81-F-150-Explorer !!
Old Jul 18, 2010 | 11:27 PM
Franklin2's Avatar
Franklin2
9.5v at the coil sounds about right.
Old Jul 20, 2010 | 03:00 PM
81-F-150-Explorer
Originally Posted by fordnewbie42
Thanks guys I found my problems. Sometime before someone else cut the tape off the harness, and guess what. There were at least 8 splices in the resistor wire alone! It overheated and melted a few with it.
It's funny how people will splice a wire that states right on the thing, "DO NOT CUT OR SPLICE" on it.
You are welcome. Anytime.
jiminn
Dec 30, 2014 06:08 AM
cr500monster
Oct 19, 2014 06:49 PM
jd$
May 2, 2014 07:49 AM
alacooney
Feb 17, 2001 01:49 AM
