BALLAST RESISTOR WIRE
Old Oct 19, 2014 | 12:27 PM
cr500monster's Avatar
cr500monster
Does anyone know where this is in the harness or am i going to have to unwrap the whole thing to find it ?
Old Oct 19, 2014 | 01:17 PM
mikeo0o0o0's Avatar
mikeo0o0o0
The wire is in the main wiring harness under the dash. It goes through the firewall and terminates at the plug for the "engine gauge feed harness". This is the harness that goes to the coil and the oil and temp sending units. It's a pink wire that has "resistor wire-do not cut or splice" printed on the insulation it's entire length.
In the pictures of my '73's harness, you can see the big insulated splice where the resistor wire ties into the wire that goes to the ignition switch. The last picture is the plug that's in the engine compartment.
Old Oct 19, 2014 | 06:06 PM
cr500monster
that is the one for the ignition right cause i got one at the parts store and its a smaller gauge than that one shown in your pic and i have found 3 in the harness so far
Old Oct 19, 2014 | 06:44 PM
cr500monster
ok i find it it was the same wiire just doubled back in the harness it was broke where it was spliced in , must have broken it when putting the heater core this summer . thank you for the help
Old Oct 19, 2014 | 06:47 PM
mikeo0o0o0's Avatar
mikeo0o0o0
Yes, that's for the ignition. To locate yours, start in the engine compartment, look for the wiring harness that goes to the coil/distributor and the temp and oil pressure sending units. Locate the wire that goes to the coil and follow it back towards the firewall. Just before the firewall will be a plug, this is where the wire changes to a resistor wire. When you identify which wire it is, then you can do the repairs.
There are other resistor wires in the harness that are used for the charge system/instrument cluster.
What year is your truck? The "pink" resistor wire was used on points and condenser ignitions. I think the color changed when they switched to Duraspark (green?) but not 100% sure on that one.
Old Oct 19, 2014 | 06:48 PM
mikeo0o0o0's Avatar
mikeo0o0o0
Good, glad you got it fixed .
Old Oct 19, 2014 | 06:49 PM
cr500monster
its a 77 4wd swb 351m
Christmas
Jul 17, 2018 12:34 PM
Chips2000
Apr 12, 2018 09:09 PM
dadstan76
Electrical Systems/Wiring
Nov 1, 2009 10:00 AM
