crank trashed, help/advice please
Old Jul 25, 2010 | 03:35 PM
hollenjoe's Avatar
hollenjoe
I wasnt refering to a stock crank, there are a couple of 4" stroke W cranks in the market...
Old Jul 25, 2010 | 05:20 PM
mark a.'s Avatar
mark a.
There would be no reason for a stock 400 crank to fail unless something was wrong to begin with.
Old Jul 25, 2010 | 10:56 PM
TMI's Avatar
TMI
Hello Paul!!
I have not visited FTE, or maybe I have not read all the threads.
I am very sorry to hear about your engine issues.
I have not seen a picture of the crankshaft you had, I don't know if I am late to the party here and just missed it somewhere.
I have not seen a crankshaft fail yet. I have seen spun bearings, severely grooved up journals, worn out thrusts. But those are faults of the crankshaft.
An OE crankshaft really will handle a lot.
Old Jul 29, 2010 | 07:40 PM
mustang81's Avatar
mustang81
You ask for a new crank and i found this:Ford 6.6 400 71-82 Crankshaft Crank Kit: eBay Motors (item 380116223666 end time Aug-01-10 07:09:15 PDT)
Old Aug 3, 2010 | 07:13 PM
father/son's Avatar
father/son
wow,
Originally Posted by mustang81
thanks for that, no chit. the dear wife has agreed to help post pics for me in 2-3 days. i still need u guys op. Mr Tim. will call when have intelligent move. honestly, no matter what i do, i would PREFER u be involved. all u guys. thanks. u r d BEST grin
Old Aug 4, 2010 | 02:17 PM
maskedman's Avatar
maskedman
What did the sister rod on that throw sustain for damage?I guess I wonder what the bearing in that rod looked like.Was there an oiling issue at that journal,or was it a single (isolated)rod bearing failure?And I guess like others here,what about the main feeding it.Anxious to see the pictures of the failure.And for the record,crankshafts can and do fail without the help of lube problems or bearing failures.Have seen many crankshafts fail in heavy engines due to bending or rotating bending fatigue.Usually attributed to someone straightening a bent crank.And they almost always break at the rod fillet behind the counterweight.Another spot they fail at is the oil feed hole on the rod journal.This engine should be an interesting failure analysis when it is determined what happened where.I also should have mentioned that any cast,forged,or foundered part can have internal flaws such as inclusions(pipe),voids,or irregular grains.
Old Aug 4, 2010 | 03:03 PM
grclark351's Avatar
grclark351
2 rods on a journal are fed from different mains
Old Aug 4, 2010 | 06:49 PM
maskedman's Avatar
maskedman
I understand that,and that was why I posed the question about the mains.
Old Aug 11, 2010 | 08:09 PM
Mud Rat's Avatar
Mud Rat
I own Graham Offroad. We use 400s because of their stroke. Cheap, stock bottom ends properly prepared. We use TMI parts and beat them to death in mud trucks, hill climbers, and rock crawlers. Never trashed a crank, but if we do, will buy a regrind from TMI. It's the only cost effective way to go.
Old Aug 12, 2010 | 06:48 PM
mustang81's Avatar
mustang81
To me it's a block problem from the oil gallery or lifter, just my 02.
Old Aug 14, 2010 | 12:46 AM
mustang81's Avatar
mustang81
To mush tolerance...
Old Dec 22, 2010 | 10:24 AM
father/son's Avatar
father/son
Hey all...will post pics tonight, finnaly got new parts
Old Jan 9, 2011 | 12:15 AM
  #28
mustange70's Avatar
mustange70
Ever manage to get those pictures?
the factory 400 cranks are stronger than the blocks . . . . i have picture proof lol.
87-XL-Squared
Mar 19, 2017 04:12 PM
Hurst89
2009 - 2014 F150
77
Apr 11, 2016 04:30 PM
caharleyman
Sep 22, 2004 05:58 AM
moose94
General Automotive Discussion
19
Aug 19, 2004 09:55 AM
vatainc
13
Jun 16, 2002 09:21 PM
