302 and c4
Old Jul 15, 2010 | 11:42 AM
lgwitt's Avatar
lgwitt
302 and c4
I have a 302/c4 in and ready to start after I have the driveline shortened.
how do i get a speedometer cable from a 1980 c4 to an original 52 f1 spedo. Thanks
Old Jul 15, 2010 | 12:21 PM
norvillebob's Avatar
norvillebob
you'll have to get a new cable I believe. I used a 60" for my toploader but it was close. they do have an 80" also I got mine off ebay a regular tranny place. make sure you get the correct ends that's all. you may also need a speedo gear if you c4 doesn;t have one. I think it was $36ish shipped
bob
Old Jul 15, 2010 | 01:15 PM
sdetweil's Avatar
sdetweil
I think if you call MidFifty they can tell you where to get one..
800-252-1956
Sam
Old Jul 15, 2010 | 01:45 PM
ZOOT's Avatar
ZOOT
Smile 302 C4 speedo cable
Exact replacement with gear change is avaible from Sacremento Vintage Ford 888-367-100 or www.vintageford.com
Old Jul 15, 2010 | 02:01 PM
air5dad49's Avatar
air5dad49
Please post your results when you find one. I have to do the same at some point.
Thanks.
Old Jul 15, 2010 | 02:22 PM
GreatNorthWoods's Avatar
GreatNorthWoods
Go to your local partshouse and look at a 1970 F-150 (or is that F-100???) speedometer cable and housing. If the 52 speedometer takes a 5/8 nut and the transmission end just slides in with a keeper bracket it should work. I'm using one for my AOD and Dolphin mechanical speedometer...
Old Jul 15, 2010 | 03:03 PM
jaye's Avatar
jaye
I went to the local Ford dealer and purchased a cable & a couple speed-o gears.
Old Jul 15, 2010 | 05:43 PM
lgwitt's Avatar
lgwitt
does this mean that a cable from a late 60s or early 70s f100 will fit the trans and back of the speedo. Does it have to be from a c4 or are they all the same.
Old Jul 16, 2010 | 07:11 AM
GreatNorthWoods
From what I've seen they are pretty much the same where they go into the transmission. The difference is where it connects to the speedometer. After a certain year they went to a clip on instead of a screw on at the speedometer head. The one I got was originally for a C4 or C6 but it fits my AOD...
BlackLabel78
Jun 1, 2009 12:30 AM
sedly
Feb 3, 2009 12:35 PM
fordguy76
Apr 16, 2007 05:26 AM
dtherren
Apr 1, 2006 08:06 PM
trailman
Nov 3, 2004 12:21 PM
