67-69 differences
Old Feb 10, 2003 | 06:21 PM
gtex's Avatar
gtex
67-69 differences
Tell me of any differences between 67 and 69 F250 2wd, FE powered, auto tranny trucks.
I'm thinking, almost nothing, right?
Maybe some cosmetic stuff, but they should all interchange, no?
Old Feb 10, 2003 | 06:24 PM
Ratsmoker's Avatar
Ratsmoker
67-69 differences
I know the beds changed in 73 and the hoods changed then also. Pretty much no different frame wise. When did the I beams become cast iron? I think it was in 78. Not sure. The dask and cab chaged in 73 also.
Old Feb 10, 2003 | 06:42 PM
1968F250LWB's Avatar
1968F250LWB
67-69 differences
67 Hood side emblems were painted
69 Hood side emblems had reflectors
67 interior door handles are different than 69
67 heater control ***** are different than 69
69 has a reflector below the tail light
67 doesn't have this one.
69 has side marker lights in front
67 does not
Most of these are only common to the 67 so some parts are hard to find I have heard.
If any of this wrong please let me know so I can learn something new.
Old Feb 10, 2003 | 06:48 PM
gtex's Avatar
gtex
67-69 differences
Thanks, good info.
I guess the real question is, if I had a 67 and 69 F250 Fe Auto (Has to be C6 in the 67, right). I should be able to select the best of the parts and combine to make one good truck. Provided there is at least one good part present.
Old Feb 10, 2003 | 06:51 PM
flyboy2610's Avatar
flyboy2610
67-69 differences
Except for the differences listed, pretty much anything will interchange between '67-72.
Old Feb 10, 2003 | 06:58 PM
sparky's Avatar
sparky
67-69 differences
I am pretty sure almost everything will interchange between 67-79...... even the sheet metal although the body lines will not match
I think the list of what doesnt interchange is shorter than what does
Old Feb 10, 2003 | 06:59 PM
gtex's Avatar
gtex
67-69 differences
A stock 67 F250 with auto tranny, shold have a C6 and a Dana 60 rear axle, correct?
Old Feb 10, 2003 | 07:29 PM
gtex's Avatar
gtex
67-69 differences
I'll know the answers in a few weeks.
Old Feb 10, 2003 | 07:55 PM
1968F250LWB
67-69 differences
In 67 Ford used the 352V8
In 68 they replaced it with the 360.
Old Feb 10, 2003 | 08:35 PM
gtex's Avatar
gtex
67-69 differences
Like I said, I'll know the answers in a few weeks.
Please, no comments about me paying too much. It's my money!
Any comments about how good it looks are greatly appreciated :-)
I'll be combining these 2 trucks.
My current project gone sour:
http://www.thedreyerfamily.com/69f250/69_f250.htm
and my latest internet gambling adventure:
http://cgi.ebay.com/ebaymotors/ws/eB...402061248&rd=1
Some of you may have seen the reason my current truck needs some serious help in the body department.
http://www.thedreyerfamily.com/crap/nightmare.htm
reasons I found this one so tempting:
1. It looks to be very straight and clean.
2. It's colors work with the parts I already have for the interior. the exterior will probably match my monster gas tank! Although I planned to paint it eventually.
http://www.thedreyerfamily.com/69Gas.htm
3. It's an F250 as well, almost all parts should swap.
4. It has AC, which I wanted.
5. It has the stupid intake air box that I need to get inspected :-)
Here are some more pics I recieved from the seller after the auction ended. I feel better.
http://www.thedreyerfamily.com/67F250.htm
I'll be moving most of my drivetrain to the 67. There should be one really nice truck and one that needs a little love here shortly. Both should be runners. Or, I may have a parts clearance on the classifieds here.
Old Feb 10, 2003 | 10:32 PM
460 Crew's Avatar
460 Crew
67-69 differences
Both of your trucks look good and straight , my question is what is up with the 90 gal bomb in the bed for? Do you buy gas by bulk wholesale and fuel the rest of your fords at home. I know these old trucks aren't good on gas but thats just a little to big for me . Good luck on the 67and 69 you'll end up with some good lookin trucks.
Patrick
1970 F250 CrewCab 4x4 460 C6
Old Feb 10, 2003 | 11:55 PM
zsir's Avatar
zsir
67-69 differences
Wow....Looks like you're serious about having a vintage F series truck....
You've inspired me to post some picts of my current money pit......err......project....
How do you like the crower cam your using....? does it make good power ....how does it idle....?
I'll buy that 69 grill if you don't use it......I have a 71 but I'm determined to get a 69 grill....
Old Feb 11, 2003 | 07:47 AM
gtex's Avatar
gtex
67-69 differences
The Crower Cam has a nice sound, lopes at idle. I think it's a little weak on the bottom end, but there may be other items holding back the ponies. I'm still running stock heads and valve train.
The cam was reccomended here by some of the FTE guys, so it must have some redeeming values.
Big Gas tank! Think, 390 FE, big cam, 3 speed auto, 4.10 gears and 29.5" tires on a heavy vehicle with the aerodynamics of a brick!
In addition, I want space behind the seat and I like true dual exhaust. So, the other tanks are inconvenient.
The 90 gallon tank was actually a lot cheaper than some of the smaller tanks.
Old Feb 11, 2003 | 11:53 AM
BB's Avatar
BB
67-69 differences
A stock '67 with a 352 (only FE offered that year) would have had an MX trans, a HD version of the FMX Cruise-O-Matic.
'68 is when the C6 became available with the new 360 and and 390.
Barry
Old Feb 11, 2003 | 12:32 PM
John72_CS's Avatar
John72_CS
67-69 differences
Sounds like you've got a good bit of work ahead. The poor '69 was just rusted away. Mine had similar problems, cept most of the rust is in the floorboards of the cab. Their professional paint job was a bondo screwup waiting to fall apart. The stuff doesn't stick to rust.
Good luck getting a running, working, hauling truck going gtex. Looks like the '67 should be good for you.
