Larger Fuel Tank
Old Jul 21, 2010 | 07:53 AM
rickatic's Avatar
rickatic
You will not see much more fit in with the drizzle it in method. My new truck fills all the way to the top. I drizzled it a couple of times at first. Never got more than a half gallpn more in it. I started out fueling with a quarter left. It took 16 gallons or so. I then started working down the miles to empty counter. When my counter shows 20 miles to empty, ot still takes less than 20 gallons.
Old Jul 21, 2010 | 08:01 AM
Rafiki2cu's Avatar
Rafiki2cu
With the 20 miles to empty what does your fuel gauge show.
Old Jul 21, 2010 | 09:35 AM
skylinekw's Avatar
skylinekw
The short box Crew cab is 26 gallons. With zero miles on the miles to empty all I could get in was 20 gallons
I could have read it wrong but I thought ford's web site said the crewcab both long and short bed had a 37.5 gallons
2011 Ford Super Duty | View Vehicle Cargo Capacity | FordVehicles.com
Old Jul 21, 2010 | 09:41 AM
Rafiki2cu's Avatar
Rafiki2cu
Yep that is what I read, I quess with Job 2 you get a bigger fuel tank.
Old Jul 21, 2010 | 10:44 AM
02MDP7.3's Avatar
02MDP7.3
Got to looking around on Ford's site, and fuel tank capacity is based on wheel base. 142" & 156" WB has 26 gal tank, 158" & 172" WB has 37.5 gal tank.
2011 Ford Super Duty :Options | Compare all available trim levels for the 2011 Ford Super Duty | FordVehicles.com
Old Jul 21, 2010 | 10:50 AM
Rafiki2cu's Avatar
Rafiki2cu
My question is if a 6.7 CC 6.5 bed 4x4 is 156 inches what would a 158 wheel base be?
Old Jul 21, 2010 | 10:53 AM
02MDP7.3's Avatar
02MDP7.3
I'm thinking cab & chassis. Maybe. ?!?!
Old Jul 21, 2010 | 11:00 AM
Rafiki2cu's Avatar
Rafiki2cu
This one has me stumped, I called my parts dept. and got a price for the 37.5 tank in the 390.00 range but it is for 158 wheel base only. I asked what set up would be a 158 and they did not know.They did say to measure and see if I had 158 instead of the 156 that the vin. says.
Old Jul 21, 2010 | 11:20 AM
Rafiki2cu's Avatar
Rafiki2cu
I read Fords specs and a 158 wb is SC LB but if you read the capacities a CC SB is 158 and a SC LB is 156. Now I am really confused.
Old Jul 21, 2010 | 11:25 AM
EpicCowlick's Avatar
EpicCowlick
I wrote a letter to Ford letting them know that I think I'm entitled to a 37.5 gallon fuel tank. We'll see how that turns out.
Old Jul 21, 2010 | 11:29 AM
Rafiki2cu's Avatar
Rafiki2cu
Maybe we should all sign a petition and send it signature required.
Old Jul 21, 2010 | 05:42 PM
radzer0's Avatar
radzer0
Heres how the ford fuel tanks work.
Reg cab 35 All
Supercab and Crewcab gassers. 35
Why the supercab comes in 3 wheelbases i have NO clue. But it does say that the crew cab only comes in 158inch and 172inch wheelbase.
So does that mean we can put a 35gallon gasser tank in our diesels?
Old Jul 21, 2010 | 07:02 PM
  #28
02MDP7.3's Avatar
02MDP7.3
I will run mine down as far as I feel safe tomorrow and see how much it takes to fill. I'm still thinking it's a 26 gal.
Old Jul 21, 2010 | 07:14 PM
  #29
Rafiki2cu's Avatar
Rafiki2cu
Reg cab 35 All
If you look at capacities 6.7 CC comes with a 37 gallon tank. I have a CC so I must have a 37 gallon tank. Wow who would have guessed
Old Jul 21, 2010 | 07:17 PM
  #30
Rafiki2cu's Avatar
Rafiki2cu
Correction I must have a 37.5 gallon tank.
