tire wear issue.
Old Jul 14, 2010 | 01:34 AM
David85's Avatar
David85
Agreed, try taking the blocks out, since that will reduce your positive camper. They look to be an add on by some one.
Old Jul 14, 2010 | 01:50 AM
Blueovals&Blacksmoke's Avatar
ok i just hope that the u-bolts arent going to break if i put a half inch breaker bar on them. ill soak them in diesel for a few days prior.. ok thanks guys
Old Jul 14, 2010 | 02:02 AM
oreocreaming's Avatar
oreocreaming
just a bit of penetrating lube will do.
Old Jul 14, 2010 | 11:00 AM
Festus Hagen's Avatar
Festus Hagen
Methanoholic
Originally Posted by Blueovals&Blacksmoke
i realize thats whats going on and i thank you for all your shared knowledge but my questions are not being answered.
A) if i take the plate out would it help?
B) is the plate stock?
C) does it help to hold anything in place?
these are what i need answered. i know theres bound to be some stuff wore out after 330K miles but for right now being broke as a joke. having a DOLLAR to my name im trying to make my truck last as long as i can.
Yes, that plate is stock!
Yes, Removing it will affect camber!
Yes, It is part of the locating pin!
Removing it allows no place for the locating pin to key into!
The only resolution is parts replacement and alignment, no backyard DIY hack jobs are going to resolve worn out parts and alignment issues!
An alignment is cheaper then constant wear on tires.
I know thats not what you want to hear, but it's the facts!
-Enjoy
fh : )_~
Old Jul 14, 2010 | 11:29 AM
oreocreaming
-Enjoy
fh : )_~
so, what the hell good is it if its just floating on top of the axle? if its not welded to the axle then its worthless in holding the axle from shifting back and forth. would make more sense to drill a hole in the axle for the pin to recess into. there could have been either thicker material in that area or a second plate under it to cap under the location hole.
Old Jul 14, 2010 | 12:31 PM
David85's Avatar
David85
-Enjoy
fh : )_~
I didn't know that. Good catch.
My manual makes no mention of it in the diagrams though so I don't know what to think.
Old Jul 14, 2010 | 01:08 PM
thats what i was thinking. i know i cant be the only person to think that it would help the camber issue on this junk front end. but its what i have so i have to work with what im given. i love doing fab work so im guessing ill have to do a little bit to it.
Old Jul 14, 2010 | 02:09 PM
starmilt's Avatar
starmilt
X2 what festus said.
Old Jul 14, 2010 | 04:12 PM
Coalroller's Avatar
Coalroller
it was stock on mine but the center pin bolt goes through it and sticks outta the bottom into the hole in the spring perch, so it does help center the spring pack and is stationary being that the pin bolt head does keep it from floating aound
Old Jul 16, 2010 | 09:07 PM
Dave Sponaugle's Avatar
Dave Sponaugle
There are three steering angles/measurements that have to be taken into consideration.
Caster
Camber
Toe in
On a leaf sprung vehicle, if you want to change the caster, you use a wedge shaped plate in that location.
Which way the wedge slopes and at what angle tilts the axle forward or backward to adjust the caster angle.
In reguard to IFS/TTB front axles, the most important part of caster is the angles match on both sides.
With a D 60, the angles match because both knuckle yokes are attached to the same axle tube.
With an axle that is two piece like the D 44 and D 50, the only thing that keeps those angles the same is where they bolt against the leaf springs.
Hence the need for wedges to adjust the angles.
The next one is camber.
If the front tires sit like this / \ it has negative camber
If the front tires || the camber is zero or neutral.
If the front tires sit like this \ / the camber is positive.
The TTB axles used in the 250 trucks like slightly negative camber.
Camber is what makes lifting a truck with a TTB axle so hard and complicated which translates to expensive.
The third thing is toe in.
Almost all vehicles have a slight toe in to help with cornering.
From memory I have mine set at 1/8", IE the front of the wheels are 1/8" closer together than the rear of the wheels.
My take on your tire wear.
Excessive toe in or positive camber for equipment related issues.
That tire wear could also be from driver induced wear if you take the corners excessively fast.
Roll into a corner hard, crank the wheel hard almost to the point of squealing tires with you foot hard on the brakes, a 4 ton vehicle puts a huge load on the outside edge of the corners outside front tire.
Here is a little more information above what I stated above about alignment.
Caster, Camber, Toe
So if you remove those plates, you may actually be making the problem worse if they are wedges to adjust the caster.
A 1/2 degree wedge would look almost like a piece of flat metal to the eye.
tlapham
Oct 1, 2010 06:03 PM
68
Aug 2, 2010 12:10 AM
draginlow
Jul 30, 2010 12:36 AM
76f350spercamprspeal
Picture competitions
Jul 2, 2010 02:02 PM
cfmetal16
Jan 18, 2010 02:52 PM
