bad smog pump= run bad?
Old Feb 10, 2003 | 05:13 AM
big_saxy's Avatar
big_saxy
who has removed their smog pump? without problems to the ecm. I have a 93 5.8 E4OD..... I have cold start problems, erratic Idle and a light throttle surge, could a bad smog pump cause the ecm to throw codes at Idle... or just too much air or fuel? code 327... egr-evp... TPS code as well as a o2 code... changed everything!
Old Feb 10, 2003 | 12:58 PM
honney's Avatar
honney
Not the air pump
Old Feb 12, 2003 | 02:56 AM
big_saxy's Avatar
big_saxy
what about the air speed control motor?
Old Feb 12, 2003 | 07:31 AM
steve83's Avatar
steve83
Stop spending money on parts you don't need and buy a digital multimeter & a Haynes manual. It tells how to test each device & circuit so you'll know where the problem is.
Old Aug 13, 2005 | 12:08 PM
crow's Avatar
crow
Question bad smog pump??
What would be some signs of my smog pump going bad?
Old Aug 13, 2005 | 02:25 PM
handyman43358's Avatar
handyman43358
I doubt thats the problem. I know a few guys who have yanked their pumps off and have no change at all.
Old Aug 13, 2005 | 03:12 PM
IB Tim's Avatar
IB Tim
FTE Leadership Emeritus
...Welcome to Ford Truck Enthusiasts! Please read the Guidelines, it will help you to navigate through and understand this site.
We are happy you have chosen the best source for Fords!
Enjoy FTE....and
JOIN CLUB FTE -SUPPORT THE FORUMS!
…..See you on the boards.
Old Aug 13, 2005 | 11:19 PM
Blurry94's Avatar
Blurry94
No emissions equipment and aftermarket cats, and all is well.
Old Aug 14, 2005 | 09:17 AM
Saurian's Avatar
Saurian
I tried a new belt to "delete" the Air Pump pulley from the system. Was just a hair too big I think, and would occasionally squalk like crazy. Anybody know what size/PN I'd need for a 302? I think mine was in the 95 inch range?
Old Aug 14, 2005 | 03:19 PM
skyfox10's Avatar
skyfox10
i've taken my smog pump off, byjust pulling it off (+ extra check valves, tubes) and did't notice any differenc in anything. i will say that my check engine light has been on since i switched to long tube headers and my O2 sensor cable wont reach. my big problem is that i got a Carquest® K060947 wich is 2420mm long.
it worked for awhile untill i used my ac, it fell of once. i put it back and didn't use the ac for a while. then a couple weeks later i used my ac again and it fell off once more. after that, even without the ac it would fall off. once i was driving home at 2:30am and it came off eight times.
i went to autozone and they said that the Carquest® K060947 was 94.7 inches long and they gave me 2 belts to try, a XXXX945 (misplaces package for exact number) which was 94.5 inches long and another one which was the next size smaller.
the smallest one wouldn't fit and the 94.5 would fit so i took it. it seemed to work fine untill about a week ago when i was running the ac. so far as long as the ac is off it's ok, but it seems like such a wast to have a truck with a perfectly good ac system that you can't use.
i hope this information helps someone, and if anyone have any ideas to address my situation let me know.
Old Aug 14, 2005 | 07:32 PM
Blurry94's Avatar
Blurry94
I don't run the smog pump and I've been running a short belt for over a year now without any issues.
Old Aug 14, 2005 | 08:27 PM
cjjeeper85's Avatar
cjjeeper85
No emissions equipment and no cats, and every thing is peachy.
Old Aug 15, 2005 | 09:18 AM
RC Dan's Avatar
RC Dan
I ran a short belt on my truck for a while, too(94 w/302). I had no problems for a long time then all the sudden the belt kept coming off. It had actually rolled over the back of the tensioner pulley and stretched the belt out. Right now, I just put a longer belt back on with the smog pump. I bought a smog pump delete pulley on eBay for $48. Its made by UPR. Its supposed to have a clip so there is no chance the pulley can move or fall off. I should have it this week to install. Can't wait either because the pump's bearings are sqealing like mad.
I'd just reccomend one of those smog pump delete pulley brackets.
Glaser67
May 23, 2017 02:35 PM
crocodilerock
6.4L Power Stroke Diesel
Sep 13, 2016 02:14 PM
vinf100
1978 - 1996 Big Bronco
Mar 15, 2012 07:46 PM
oakwith
Jul 24, 2007 06:46 PM
laserred
Feb 2, 2006 09:36 PM
