Bad ECM or worse
Bad ECM or worse
Hey all,
Yesterday I started up the truck after a short drive and it stalled out before I drove away. It had a rough time starting and a bad idle, and would stay running. Suspected a bad battery or alternator, so being without my tools I dropped in a new battery (mine was about due anyhow) and it hardly started, and idled erratically, then died. CEL flickered off a couple times (on due to smog/EGR delete). Towed to the shop and they have no idea, said the alternator is fine, but timing is erratic.
I have a spare ECM that I'm going to swap in at the shop tonight and hope that's the fix...otherwise I'll get towed home, pull codes and go from there. I couldn't find much on symptoms of a bad ECM so I want to start this thread for anyone else in the future. I'll keep you all posted.
Thanks guys,
-Glaser67
Thanks guys,
-Glaser67
I agree that hooking up a code reader is necessary, & that the shop sounds crappy. You might be able to rent one from an auto parts store since you can't easily drive the truck to one. I don't know much about ECMs, but I do know that a bad capacitor on the board should be visible when you remove ECM.
Sometimes. They are sort of like a flashlight battery say. Batteries that leak are always bad, but dead batteries don't always leak. If they are 10+ years old they are getting up there in terms of lifespan anyway.
Thank you everyone for your replies. I would like to report back:
Agreed that the shop (who has done good work for me previously) is off my radar. In order to pull codes you have to jump the STI wire that I put in the main test connector to the cod reader. Simple to do, but they could have called and said they were having problems with doing it...
About all I know they did was at least verify me alternator was good. Geez, thanks guys. Other than that no help.
Back when I did the MAF conversion, I didn't bother to re-loom/tape the main harness connector where it plugs into the ECM. I suspect the rain during when she was acting up might have caused the issue.
So I grab my code reader and old ECM, and when I go to start her up, low and behold she fired right up. I went home and taped up the connector on the firewall, and pulled the codes.
31: EVP - No surprise, whole EGR is blocked off and disconnected.
41: System lean - I'll dig into this one
91: System lean - System running lean, fuel control
So any suggestions for codes 41/91? Obviously I'll check for leaks, and before I re-pull codes I'll get the O2's nice and hot first...and post pictures of the plugs too.
Lastly, she has not cted up like that since I sealed up the harness connector. I did find that all 3 of my capacitors were leaking a bit on my A9L, so I'll get that handled and report back if I notice a change.
Thanks all,
-Glaser67
Thanks all,
-Glaser67
rsplash40
05-26-2016 03:09 PM
