Speedometer gear
Old Jul 11, 2010 | 09:53 AM
blsd49's Avatar
blsd49
Speedometer gear
My '49 F1, stock 6 cyl., 3 speed:
the speedometer reads low, maybe 2/3rds of actual speed.
At Dennis Carpenter I see they show gears with 19,20,21and 22 teeth.
Maybe I am running the wrong one, or?
Any idea which one is correct?
Thanks, Brian
Old Jul 11, 2010 | 10:02 AM
ALBUQ F-1's Avatar
ALBUQ F-1
You're reporting a 33% difference; the difference between the extremes of those gears doesn't come close to that. I'd suspect your speedo needs a good clean and lube. There is a little wick on the back of the speedo, right where the cable connects, that is for oiling, try a few drops there, but it is internal where it likely needs lube.
Are you running tires close to stock? (diameter)
Old Jul 11, 2010 | 10:58 AM
blsd49's Avatar
blsd49
Yes stock 16" tires. I will check the lube;just thought there would be some erractic behavior with the dial like when the cable needs lube.
The speedo has been like this since last resto and really isn't a big thing as it is not a daily driver and I don't push it.
Sounds like I need to pull the cluster (a winter project);need to do that anyway as there is some dust flecks that somehow showed up right after installation. Ugh!
Thanks, Brian
Old Jul 11, 2010 | 12:14 PM
ALBUQ F-1's Avatar
ALBUQ F-1
You're right, if it were purely a cable problem you'd see it jumping around. Mine failed right at 99,992 miles because the drum that moves the needle (which isn't directly connected to the cable) wore out its bearings, and started hitting the drum connected to the cable. It would be the only time I saw 85 mph on it!
It's really tough to open the unit up without ruining the chrome trim ring.
Old Dec 1, 2010 | 04:21 PM
Zel67's Avatar
Zel67
I don't think it matters if it is accurate, it's not fast enough to be speeding anyways. You should get the dust out of it though, or maybe do it right the first time!
Old Dec 1, 2010 | 05:19 PM
blsd49's Avatar
blsd49
Always nice when your son chimes in !!!
Be careful or I will leave it to your sister!
Old Dec 1, 2010 | 05:26 PM
Zel67's Avatar
Zel67
she can't even drive a stick! That truck is mine!!
Old Dec 1, 2010 | 05:30 PM
havi's Avatar
havi
I'll have the Roast Duck
Leave it to me.... problem solved.
Old Dec 1, 2010 | 05:56 PM
Julies Cool F1's Avatar
Julies Cool F1
Ok well lets confirm that you have the stock rear end in the truck too. If so then you shouldn't even be able to get it up to 65 (maybe downhill, with a good wind at you back, at 3500rpm). 2/3 of that would be 32mph!!!!!!
2/3 of acutal speed is quite. My 51 with a 2.80 rear has a speedometer that reads exactly 10 MPH slow at 70 mph.
Curious, how are you clocking your actual speed?
Old Dec 1, 2010 | 10:40 PM
blsd49's Avatar
blsd49
Julie, yea stock rear end. Clocking actual speed by traffic and also based on the speed of someone else in a newer vehicle. Figure that at about 55 mph it shows 40. It is not a huge issue as I only drive it into town and back, about 7 miles each way and that only 20 to 30 times a summer. Just would like to correct it if not a big deal; oh and of course I need to remove the dust behind the glass that showed up after installation as my son pointed out! brian
Old Dec 2, 2010 | 02:41 AM
Julies Cool F1
As Ross mentioned, the chrome ring holding the glass on is attached at four places where the edge of the crome ring is bent and tucked under the speedo housing. You just need to "CAREFULLY" pry out two of those crimps on the same side to get the chrome ring off to clean the glass. Be careful when the chrome ring comes off everything falls out - including the glass.
You may be able to get close with a driven gear change. I'd take it to a speedometer shop and have them put it on the dyno to give you an accurate reading and they can fix it either with gears or a reduction box. Should cost about $35.
Old Dec 2, 2010 | 05:41 AM
skipr's Avatar
skipr
Not all 16 jn tires are equal my 285 x16 stand 4 jn taller than 235x16. that would change speedo ratio quite a bit
Old Dec 2, 2010 | 08:41 AM
r_reed's Avatar
r_reed
my truck is conv to 12 volt, so i just plug in a gps and have a speedometer. i've used it to check my speedo and often use it just for the "fun" of it.
Old Dec 2, 2010 | 11:59 AM
Julies Cool F1
Cheater!
Old Dec 2, 2010 | 01:04 PM
r_reed's Avatar
r_reed
actually i'm just comparing the two to make sure the gps is accurate. it is interesting that i replaced my speed gear (HD 3speed, metal gear) with one with one more tooth (or less, can't rem) and have 2.25-75 on the rear and the stock speedo agrees within less than 1mph with the gps. i have no idea if the speedo was acc with the old gear and the 2.25-75's, just assumed it was.
twm011
Nov 23, 2016 07:41 PM
millerliteliker
Feb 1, 2016 04:27 PM
tpdaniels
Dec 26, 2013 09:41 AM
trailblazer28333
Jul 27, 2010 09:27 PM
brown 4x4
Dec 17, 2004 09:28 PM
