Speedometer and Transmission
The transmission in my 94 4.9l F150 has been giving me a few problems. From the sitting, parked, position it would take about 10-30 seconds to go into gear (reverse or drive). About a week ago while driving home, the speedometer suddenly stopped working. Now I'm experiencing hard shifts along with the previous problems. I changed the vehicle speed sensor on the rear end and the PSOM with a second-hand one. No change. The speedometer still doesn't work along with the odometer but it does light up. No visible problems with the wiring. Any suggestions before I take it the tranny shop and fork out big bucks? Would a new tranny fix my speedometer issue? Thanks in advance.
That was one of the problems!. I previously checked the number 8 fuse, but not the number 18. Now it keeps blowing the 10 amp fuse for the number 18, so I put a 15 amp in there temporarily to see if that was the hard shift/speedometer culprit, and it was. Any ideas why it may be blowing the 10a? Is there any usual areas of wear on the wires in that area?
Thanks again!
Thanks again!
77_150
03-13-2015 03:53 PM
andyw8705
06-02-2009 05:41 PM
fastvert
07-24-2008 11:03 PM
frodriguez57
03-31-2004 08:07 PM
