Sponsored by: Real Truck
speedometer not working
Old May 10, 2010 | 09:47 PM
trailblazer28333's Avatar
trailblazer28333
I have a 99 f-350 7.3l 6 speed manual. The speedometer and cruise does not work. I had an abs light on and changed the rear diff sensor, solved the abs light but the speedometer still does not work. Tried a different instrument panel with same results. I purchased this truck with this problem. I did a search on this forum and have been reading alot of different problems and all of them the speedometer tried to work or was intermintent. Mine does not work at all. From what I read it might be a pcm. one problem, what is a pcm and where is it located. Also can autozone check it or do I have to take it to a mechanic to be diagnosed. Another question I have, Is there anyway of disconnecting the speedometer that I could check and see if maybe the PO might have forgot to tell me,(fuze, wiring harness in the dash, ect.). Thanks for anyhelp
Old May 10, 2010 | 10:08 PM
dchamberlain's Avatar
dchamberlain
I'm not entirely sure, I'm a little confused on this subject. But I think trucks as old as yours also had a speed sensor on the transmission.
Old May 10, 2010 | 10:23 PM
trailblazer28333
I checked the transmission top to bottom and could only find two plugs. one was for the 4x4 indicator and the other was the reverse lights. And didn't find any other place for a plug.
Old May 10, 2010 | 10:26 PM
dchamberlain
I'm probably wrong about that then. Wouldn't be the first time. Won't be the last.
Old May 11, 2010 | 12:01 PM
trailblazer28333
how about it anyone?
Old Jun 5, 2010 | 06:36 PM
Kajtek1's Avatar
Kajtek1
Subscribing.
Today stopped for fuel and on restart -the speedometer, odometer and CC did not work.
Drove about 60 miles till next stop, restarted and it works now.
Is the darn thing electronic?
Old Jun 7, 2010 | 10:23 PM
trailblazer28333
Yes the speedometer and odometer are electronic. During the course of troubleshooting my problem I found out that the vss sensor on the rear diff sends a signal to the abs control module and the abs control module then interprets the signal and tells the speedometer and cruise control(throught the pcm) what to do. There is a gray wire with a black stripe going from the abs control module to the speedometer and pcm. In my case this wire was broke before the splice causing the symptoms you had. But since yours started working again after turning it off. I"m leaning toward the vss sensor or the abs control module.
Old Jun 7, 2010 | 10:28 PM
gearloose1's Avatar
gearloose1
Clean the contacts of the sensors, and reset the computers, make sure the batteries are load tested good and alternator output is fine.
Old Jul 27, 2010 | 09:27 PM
panzer242624's Avatar
panzer242624
my 1992 f-150 has the same problem when i got it the speedo did not work. replaced the vss or rear abs sensor and still have the problem any one know any thing about how to fix this i am driving from ohio to cali and woud like to solve this if possible
Byoung Oh
1983 - 2012 Ranger & B-Series
Feb 4, 2017 05:51 PM
crystalhand
Oct 18, 2015 09:27 PM
lindboep
Aug 25, 2012 03:32 PM
k4uwc
Sep 28, 2009 07:58 PM
cassenbl
Sep 1, 2008 06:06 PM
