CA YOM Plates
So I went to the DMV today(in Arvin) and started the registration of my '56 for the first time in 20 years. Had to start all over again. The truck was not present to be inspected so we didn't finish. The woman gave me a 30-day permit to get the truck to the DMV to finish registering it.
Got some bad news. The "63" plate that it has on it now--AND HAS ON IT'S REGISTRATION FROM 20 YEARS AGO!!!!--is not good, and won't pass. Apparently, even through the plates was issued by the DMV and used for a number of years, it isn't good now. Why, I don't know. She said the only plates that would work in it at this point would be YOM plates or newly issued. Yes, that's true! The only way the 63 plates would have been allowed is if your truck was a 63-69 (and your plate had the correct 64-69 Year sticker for you year vehicle) or you were the owner when the plates were issues and still have that original title - read posts 65 and 66 above!
Not to mention I only have one so it won't pass anyways. So I'm done there.
However if I had both I could bring them in to see IF it could be done and if it could, it would. Can't, won't, no, nyit, nine! They will just take them. You either have to get new plates or present valid registerable YOM plates (2 of them) that are the same year as your truck (or have the valid metal tags/stickers for your year with the issue year 51 black, 56 gold, 63 black or 1970 blue plates) I believe the CA YOM program is valid for cars to 69 and light trucks to 72.
But then I mentioned I had a set of NON-COMMERCIAL "56" plates in perfect condition and she said those also MAY work(not they would, but may), and to bring them in if I were serious. They SHOULD work, but remember the board in Sacremento makes the final decision NOT the local office. I just got the approival on the 51 TRL Trailer plates for my trailer and Sacremento took 3 months to process those.
All else fails I'll have to just take the new plates they give me.
OK, now we get to the juicy stuff.
I was reading today from some links posted in this thread that the sticker on a "56" plate shows the year the plate was released and NOT the year registration was renewed--unlike nowadays.
But look at my NON-commercial plate that I have:
According to the guide I just read, if I didn't know any better that looks like a "1960", "1961", and "1962" year stickers...............ALL ON ONE PLATE.
What the fck?????
I have a feeling that someone in this thread didn't quite get this right because it sounds like one plate should only have one sticker on it. PERIOD.
Does this somehow mean I can't use this plate for my 1956 F100? I am so confused.
I think you are confused because maybe it isn't clear to you that what was done to register the vehicles in the past, annually, is NOT the same as what is being done for the YOM program today.New license plates used to be issued every year until WWII in California.
But because of metal shortages, after WWII, you just recieved a metal tag to fit over the year number on the plate - YOU GOT A NEW YEARS METAL TAB EVERY YEAR WHEN YOU REREGISTERED THE VEHICLE.
Metal Tabs were used in conjunction with the CA Black 1951 plates through 1955 to show that the vehicle was properly registered for that year.
In 1957 Stickers replaced the Metal Tabs on the Gold 1956 plates, AND THEY WERE ISSUED EVERY YEAR AT RE-REGISTRATION.
However, NOW with the YOM program, all you need to have is the proper year plate with the correct metal tag (on the black 1951 plates those would be from 52-55) and that is mounted perminently over the "51" on the Black plate as the correct YOM identifier.
Or, you need the gold 1956 plate, with the correct year STICKER for your vehicle (those stickers ranging from 57 to 62) and NOW that one year sticker is left on the plate perminently to show the correct YOM.
In addition to that, you MUST ALSO have the current year and month registration stickers which are usually mounted on metal tabs also attached to the mounting bolts because there is no space for them on the older plates.
In your case you could only use the 56 plate with the 62 sticker on it in the YOM program IF your vehicle was a 1962 vehicle. But since you are putting them on a 56 you are lucky because you can just remove all the stickers and use the 56 plate on your 56 vehicle with no stickers.
By the way, here's a small tidbit about annual tags for 51-55 plates. You'd need two if you have a pair. The tags has a number stamped into them similar to the numbers on the current annual tags. If your truck has a pair of 51-55 plates, then you'd need two tags. I have a lot of 52 tags and have found a matching pair numbered tags.
On the Metal tags and stickers, there were two issued each year - one front and one back. So what Ilya is saying is 100% true except for 1954 & 55, for some weird reason they only issued one metal tag for those 2 years. Also, 60-62 only had one sticker (instead of 2 for the other years).
There seem to be more exceptions to the rules than there are rules themselves. That's one reason the DMV workers would prefere to "rubber stamp" your application with "NO" rather than do the research and process it.
I REALLY don't want to have to remove them.....man what a fishy situation. Thanks for the clarification an my issues.
But I must ask..........are you absolutely-positively-100% sure there is NO way in any case that they'd--if they were being really really nice--somehow let me leave the stickers on there? No way at all(like I'm breaking the law or killing someone or something....?
)? I mean, they're just stickers!!!(And I want 'em to stay put)And one more question: Is there any way that if I took the "56" plates out of my car and said "here I have them" that they could somehow legally take them from me without any reason or compensation and not give them back if I don't go through with using them?
I do NOT want to get these baby's taken away from me because of some technicality that I don't know about and end up defenseless.
)? I mean, they're just stickers!!!(And I want 'em to stay put)And one more question: Is there any way that if I took the "56" plates out of my car and said "here I have them" that they could somehow legally take them from me without any reason or compensation and not give them back if I don't go through with using them? I guess someone could grab them and run out the back door with them, but legally, No, those plates are your property. I had a DMV worker try to take my 51 YOM plates once because they were instructed to "Confiscate black plates" at re register. She had no clue about the YOM program. A quick chat with the supervisor cleared that up.
You could try it with the 62 sticker on it, I guess, and see what they do. Worst thing that could happen is they reject it because of the sticker and then you will know if you will "get away" with it or not. And if not then you are right back where you are today - deciding on whether or not you want to pul the stickers off.
One last thought....You could try and find someone with a 62 car or truck who has 56 plates but not the 62 stickers and needs them. You could probably trade plates and a make a few dollars for your sticker. I'm not sure how much the original stickers would be worth - I'd think at least $50 or more. Ilya would know.
I'm saying this because let's say I got to the Arvin DMV and show them the plates with the stickers and they tell the board and they say "no". So then I drive to Shafter and tear the stickers off and go through the process there..............is there a way they could say....."hey, we just reviewed these plates earlier and they had stickers.now they don't huh?!?! NO PASS!!"
That's my last question. I think I'm ready to take the chance and get this done with............as soon as my truck is on the road that is.
Thank you so very much for walking me through yet another one of my crazy-complex issues.
If they approve it, they send you a notice and a valid registration with the YOM plate number on it. If they disapprove it they send you a letter with a reason and promise to refund your $40 in 30 days. Then, you have to go to the DMV and get NEW plates for your truck (because they cancelled the old ones or th epermit will expire).
Whether or not they keep track of the plates I'm not sure of. BUT with my trailer YOM Plate, I first tried to use it on my BOAT trailer and they rejected it because they said the trailer was "Homebuilt." But 10 months later I used the same plate for my truck trailer (which I was smart enough to register as Ford built instead of Homemade) and they accepted the same plate for use on the truck trailer.
So, I think they take each request on a case by case basis.
Frankly, if you want the plates on the truck I'd do it right rather than trying to make trouble for yourself and take the stickers off in the first place. That's just my opinion though. I guess it's a matter of priorities - being assured of having the cool YOM plates on the truck, or having a cool sticker on a cool plate sitting in the garage.
Edit note: Question - do you have the 62 stickers on BOTH plates or just one (should be just one)? If just one with the sticker, you will have to take both in to prove you have 2 of them. While still quickly showing both plates to the clerk to prove you have 2 of them and slip the one with the sticker back in your notebook or paper work so it can't be seen again. Give her the one without the sticker to photocopy and send to Sacremento. She may not realize that you have given her a little slight of hand because she probably won't know the difference and will be trying to figure out the computer and process. If she's on top of things (DMV?) and asks for the one with the sticker than you'll find out what the board has to say anyway. But understand, you can still get a ticket for having it on the 56 with the 62 sticker or be told to take it off once the plates are mounted - I'd put that one in the front if you do this.
Be smart but act stupid - and thankful!
morotbreath, just take a heat gun to your plate and carefully remove the sticker. Then take the plates into DMV. When you get them back, put the sticker back on if you want to. No sense in trying to figure out whether the DMV will accept your plates with the 62 sticker. Remember, you're dealing with the DMV. From my experience, the monkeys at the zoo have more brains and common sense.
