AC Drain
Old Jul 10, 2010 | 01:39 PM
Dresser77502's Avatar
Dresser77502
AC Drain
I was cleaning the inside of my 99' today. When I lifted the passenger side floor mat the carpet underneath was wet. I started looking for the AC evaporator drain under the truck. I can't find it. Can someone tell me where it is?
The blower fan also has water running out of the fan housing at the bottom of the fan mounting flange. I know it's related to my first problem. How hard is it to get the fan out of the housing? Will it uncover the evaporator drain?
Thanx.
Old Jul 11, 2010 | 08:40 PM
bama29fan's Avatar
bama29fan
its not hard to get the blower out. i just did it last weekend. i took some pictures and was planning to do a wrtie up on it. there are three screws that hold it in and i removed the piece thats in front of th blower (not sure what it is) to make it easier to get the blower out.
Old Jul 11, 2010 | 08:53 PM
big poppa's Avatar
big poppa
Could it be his heater core?? Thats a know spot for leakage, is it condinsation(water) or antifreeze??
Old Jul 12, 2010 | 07:04 AM
Dresser77502
No it's AC condensation. There's no coolant in it. Plus I can find cold water on the backside of the inner fender. I just can't find the drain line/hole.
Old Jul 12, 2010 | 04:33 PM
zx250's Avatar
zx250
Of the next Riffraff East
It's a pain to find and they do get stopped up. It drips right on the pass. side leaf spring behind the front axle. They're is a small hole in the bottom of the seam. You can use a small piece of wire to unplug it and get it draining again. It's easier to feel it than see it. Just reach in and under the fender well, find the hard plastic, follow the seam down and back towards the cab. Outside is flat, inside is rounded with a small hole in the middle. You will have to contort you hand and wrist, but you can do it.
Old Jul 12, 2010 | 05:22 PM
izzybird's Avatar
izzybird
Didn't just rain did it? I've noticed mine has started leaking now that it finally started raining down here again. Filled the channel on the door sill full night before last. I believe I read on here that it's from around the windshield, and a semi common problem. Maybe someone else knows for sure and will pipe in. Just a thought anyway.
gray035
13
May 8, 2017 02:12 PM
Wolfboro
Jul 25, 2015 05:17 PM
BeerCan500
13
Aug 28, 2012 09:07 PM
coralbrief
Aug 19, 2012 07:02 PM
dawson2381
Escape & Escape Hybrid
Jul 9, 2010 05:58 PM
