Mystery E-Brake light
Old Jul 9, 2010 | 10:58 PM
ASNWRULZ's Avatar
ASNWRULZ
So I've got an '82 F150 2wd with a 300-6 and a C-6 and the brakes have never been the high point of my truck. A few months ago the E-brake light started coming on while driving then would shut off when the pedal was pressed. Then after a week or two it just stayed on all the time. After checking the E-brake system itself (which is not in working order) and the fluid in the reservoir, everything seemed to work fine but the damn light wouldn't turn off. Just the other day while pressing the brakes, the pedal built pressure but then went further down after a few seconds and the light went out. On the next push of the pedal it came back on. Now it's a intermitant thing with this stupid light. Any thoughts?
The front brakes are all new (calipers, pads, rotors) and the back ones are probly 15+ years old and noisy, ready for a change soon...
Old Jul 9, 2010 | 11:10 PM
Rogue_Wulff's Avatar
Rogue_Wulff
That same light also comes on when there's a problem in the hydraulic system. I got a feeling this is the case here.
I'm not sure if the park brake was tied into that light in 82 or not. I know it's not on my 80.
Old Jul 9, 2010 | 11:17 PM
Franklin2's Avatar
Franklin2
Follow the brake lines down from the master cylinder till you run into a block with lines running out of it. This block is the proportioning valve. There should be a single wire plugged into the block. Unplug this wire and see if the brake light goes out.
If it does, you have problems with your system, and it's making the plunger in the valve slide over and turn the light on.
Old Jul 9, 2010 | 11:28 PM
ASNWRULZ's Avatar
ASNWRULZ
I'll check it out in the morning. I do know the same light used to work with the E-brake applied years ago when it did work. What are some good words of advice for replacing the propotioning valve? Obviously got to bleed it all after being done, but is this common? My dad did replace the master cylinder years ago, not sure if he did the valve at the same time though. Guess I'll start pricing 'em out just to be safe...
Old Jul 10, 2010 | 10:05 AM
Franklin2's Avatar
Franklin2
The proportioning valve turning the light on(if that's the case) is not a sign that the valve is bad. It's a sign that you have different brake pressure between the front brakes and the rear brakes, and you need to get that fixed.
Old Jul 10, 2010 | 10:33 AM
81-F-150-Explorer's Avatar
81-F-150-Explorer
1980-1983 does not have a factory E-brake light. The Brake light on the dash is for warning of imminent main service brake failure. Most comon problems is the rear brake wheel cylinders, a faulty brake line, or the master cylinder. Also check the fluid in the master cylinder. Low fluid can show you which end of the truck to inspect.
The first year of the combination E-brake and Service Brake warning light was 1984, and was federally mandated by the FMVSS (Federal Motor Vehicle Safety Standards). Other firsts for 1984 mandated by the FMVSS was the clutch start switch (to prevent you from starting the truck with the clutch engaged, and key in ignition buzzer.
Old Jul 10, 2010 | 11:06 AM
eqppwqqep's Avatar
eqppwqqep
My 84 light is intermitten as well. If I lift on the ebrake pedal, it goes off. It's just worn on mine. Sometimes on, sometimes off.
Old Jul 10, 2010 | 11:26 AM
81-F-150-Explorer
The cable tension is out of adjustment. There is a adjuster where the single cable from the e-brake pedal meets the two cables the go to the rear brakes. Tighten this adjuster untill it's tight enough to hold the pedal up and keep the light off.
This should not be a problem with the 1982 mentioned earlier, as the brake warning light does not have anything to do with the e-brake 1980-1983 from the factory. (unless some previous owner or dealer wired it)
Old Jul 10, 2010 | 07:53 PM
ASNWRULZ's Avatar
ASNWRULZ
I'm 100% certain that the light worked with the E-brake when it worked years ago. My dad had a real bad habit of leaving it applied and driving off, hence its later failure. But yeah I pulled the connector off and it went out. Like I have said before the back brakes haven't been touched in over a decade. It's gunna get all new hardware, shoes, drums, wheel cylinders, etc... when I do the back brakes. Guess I'll see if that cures it
Old Jul 11, 2010 | 04:00 AM
81-F-150-Explorer
There was a dealer kit you could buy over the counter to have the Brake warning lamp work with the e-brake before 1984. 1984 is the first year it was factory wired that way.
Old Jul 11, 2010 | 12:02 PM
ASNWRULZ's Avatar
ASNWRULZ
My grandpa and the original owner had tons of factory and aftermarket stuff installed for towing before we got it in '91 so I wouldn't be suprised if one of 'em had that done to.
Old Jul 11, 2010 | 06:46 PM
rstrong's Avatar
rstrong
Wow both the buzzer and the clutch start switch has been removed on my 86
Old Jul 11, 2010 | 11:00 PM
ASNWRULZ's Avatar
ASNWRULZ
I don't blame ya, my dad had an '84 with that stupid buzzer. The only thing more annoying that it was the horn, it was kinda "wimpy" for such a nice truck. No buzzers for me luckily
lamenytro
Jul 19, 2013 03:01 PM
jasonc78
Jan 14, 2012 09:44 AM
ztodd377
May 28, 2010 03:10 AM
Insix6
Jun 1, 2005 06:48 AM
cds0384
Jan 31, 2005 04:36 PM
