1984 F250 rag joint free play
Is there sufficient free play in this joint that would cause the steering to wander?
******** width="480" height="385"><param name="movie" value="http://www.youtube.com/v/aOyDfWW-XhI&hl=en_US&fs=1"></param><param name="allowFullScreen" value="true"></param><param name="allowscriptaccess" value="always"></param><embed src="http://www.youtube.com/v/aOyDfWW-XhI&hl=en_US&fs=1" type="application/x-shockwave-flash" allowscriptaccess="always" allowfullscreen="true" width="480" height="385"></embed>*********>
My rag joint didn't appear to have freeplay, so I didn't do anything to it for a couple of years, but when I did replace it recently, it made a noticeable difference. If your steering box needs adjustment, that makes a huge difference - there is a proper procedure outlined in the Haynes manual.
I also agree with Festus.....the replacement joint I was supplied was a cheap aftermarket brand. I had to spend time making it usable & safe.
Its amazing the difference in price for a rag joint. Borgeson wants over $100 while Lares only charges $35 for a complete unit
http://www.jegs.com/webapp/wcs/store...Term=rag+joint
Lares Corporation items - Get great deals on power steering gear, manual steering items on eBay Stores!
on
That Lares is a POS do not use it ... You will regret it!
It is not a proper replacement and needs modification to work!
It's a cheap POS!
I wound up having to custom make shoulder bolts to make it work, I am about to replace it properly now that my truck is down and apart.
-Enjoy
fh : )_~
It's a cheap POS!
-Enjoy
fh : )_~
It's a cheap POS!
-Enjoy
fh : )_~
It's a cheap POS!
-Enjoy
fh : )_~
1980-96 NEW Ford Steering Rag Joint Coupler: eBay Motors (item 260350973998 end time Jul-16-10 11:04:47 PDT)
Ok one last ditch attempt. I just found that Borgesons have rag joints but which one? There are 5 pages of them. This is giving me some hope of saving at least $180 on a new shaft.
https://www.borgeson.com/xcart/searc...keep_https=yes
on
I don't know exactly what you have, I can only go from what I have and there is no certainty that what I have on my 86 is either the same as yours or even factory to mine!
If I counted correctly the gear box is 3/4"-36 spline, I need to verify.
However, between my 86 and 91 each one is different from the other.
The 86 I do not like anything about, shaft, upper joint or rag joint!
The 91 I like the upper joint and shaft, the shaft at the gear box is solid 3/4"DD, I'm going to cut the factory rag joint off and replace with Steering Universal Joint / Vibration Damper, Steel, 3/4-36 X 3/4DD, One could also use Steering Coupler, OEM Rag Joint Style, 3/4-36 X 3/4DD.
However neither one of those will work on the 86 shaft, on my 86 the shaft is a tube with the rag joint end squished to a 1"DD, I see it as a pain to adapt! I suspect your 84 is the same.
-Enjoy
fh : )_~
-Enjoy
fh : )_~
Fishin76
42
12-15-2010 07:56 AM
ebexp94
2010 - 2014 Ford SVT F150 Raptor
06-14-2010 05:30 AM
