Weird E-brake
Old May 31, 2005 | 10:52 PM
Insix6's Avatar
Insix6
Weird E-brake
A couple days ago, I put my 92 F150 in park and applied the e-brake. When I did, the e-brake pedal went all the way to the floor. My first thought was that the cable snapped but when I got under the truck to check, everything seemed fine. I pulled the brake release button and tried it again. Everything seemes to be all right. Is this normal? My truck only has 45,000 miles on it, and I live in Indiana so I don't use it much. It still keeps the the truck from moving when I put the truck in drive and let off the brake. Is something broken or is this just something that happends?
Thanks for your help guys
Old Jun 1, 2005 | 06:48 AM
low92flareside's Avatar
low92flareside
Check the adjustment on your rear brakes...
Climb under the rear of the truck between the rear tires. Look at the back of the brake drums and you'll see a small rubber plug about 1 inch long. Pull it out and it'll reveal a small gear. Use a flat head screwdriver to turn this gear to tighten the brakes. Pop the rubber plug back in and your ready to go.
Another way to tighten the rear brakes up would be to do a couple of hard stops in reverse. They're self adjusting brakes, and if you don't use them in reverse too often, they'll loosen up.
jasonc78
Jan 14, 2012 09:44 AM
bigunit54
2004 - 2008 F150
Aug 3, 2011 05:23 AM
ztodd377
May 28, 2010 03:10 AM
superduty4x4
53
Apr 13, 2009 10:56 AM
Eric_F250
Feb 18, 2009 10:09 PM
