Two questions
Old Jul 9, 2010 | 02:11 PM
Brown Falcon's Avatar
Brown Falcon
intake, exhaust, custom tune chip like a PHP, DP Tuner, or TW
Those mods should help quite a bit. Especially replace the intake and the stock downpipe if you still have it.
Old Jul 9, 2010 | 04:45 PM
bearhugger's Avatar
bearhugger
Yes i still have the stock air filter and down pipe also the cat,will probable replace the filter and cat.
Thanks
Old Jul 9, 2010 | 06:29 PM
Brown Falcon
Thanks
The 6637 filter mod is very popular here. Also, gutting the cat or deleting it all together.
Probably the most restrictive part of the exhaust is the stock downpipe. It's like a flat pancake instead of a round pipe. A 3" round downpipe can be bought for under $100 and is relatively easy to install.
I have pictures from my downpipe install that I could send if you need them. Just send a PM if interested.
Old Jul 10, 2010 | 10:08 AM
oldbird1965's Avatar
oldbird1965
I have a 2wd (I would never pull in 4by4 even if I had 4by4) and pull what you see in my signature and if I get 10mpg I'm happy. I run the crap out of it also because I want to get there and to H*** with mpg.
Old Jul 10, 2010 | 11:14 AM
thebig350's Avatar
thebig350
Glenn, I hereby declare you the winner of this thread.
Old Jul 10, 2010 | 12:11 PM
427 fordman's Avatar
427 fordman
hahaha Good one glenn, I hear ya
Old Jul 10, 2010 | 12:25 PM
drivembig's Avatar
drivembig
I was fighting the fuel mileage problem when I first got my truck. I realized that the biggest difference that I saw was the kind of oil that was being ran in the truck. I don't know what the previous owner was using, but it had to be bad. I changed it to Mobil Delvac (and that isn't the best by far) and my mileage increased about 5 miles per gallon.
I know I have heard some of these guys using synthetic and helping quiet a bit as well.
Old Jul 10, 2010 | 02:55 PM
B Big's Avatar
B Big
My 4 door dually 95' got 17.86MPG (9400 miles MPG test) with crappy oil & fuel leak(s) in the valley!!
I have switched to 15w-40 Amsoil. I will post the MPG results soon. My engine sounds & runs sooo much better with the Amsoil !!!!!
I am still running down the fuel leaks & plan to switch out the down pipe & do the Riff Raff intake.
I am REAL happy with this truck's MPG, 20% better than my 03' Navigator! & thats BEFORE the switch to synthetic oil.
JimKam
Jan 29, 2012 12:28 PM
Jimmy Mac
13
Jun 1, 2011 06:26 PM
Jim McQueen
Bronco II
Jan 11, 2008 10:12 PM
true blue
13
Apr 6, 2002 11:12 PM
