5 speed to Automatic
Old May 31, 2011 | 04:22 PM
Jimmy Mac's Avatar
Jimmy Mac
I have a 1994.5 f 250 five speed manual 2 wheel drive
What would it take as far as parts to change it over to an auto??
Does it need a different computer for an auto and what about the shifter?? Do they make an aftermarket floor shifter so I wouldn't need to do the steering column
thanks JIm
Old May 31, 2011 | 05:46 PM
fordpride's Avatar
fordpride
All the parts out of my auto truck what state are you in
Old May 31, 2011 | 05:50 PM
fordpride's Avatar
fordpride
You need PCM, steering column, shift linkage under truck ,cross member, driveshaft, wiring harness for auto trans. am i missing anything guys
Old May 31, 2011 | 05:57 PM
superduty4x4's Avatar
superduty4x4
There is a piece of the trans tunnel that is bolted on that needs to be swapped also.
Old May 31, 2011 | 06:05 PM
Krisx125's Avatar
Krisx125
A spacer that goes on the flywheel also.
Old May 31, 2011 | 06:16 PM
jg96powerstroker's Avatar
jg96powerstroker
O THAT DAMN SPACER!!!!! man when it hits you in the head it hurts!!!
Old May 31, 2011 | 06:37 PM
Jimmy Mac's Avatar
Jimmy Mac
Thanks for all the replys
I'm thinking it's staying a stick
Old May 31, 2011 | 06:46 PM
helifixer's Avatar
helifixer
you could just buy my '95 2 wd auto and swap it out than sell the truck for parts or make it a 5 speed and sell it.
it only has 140,xxx miles on it
Old May 31, 2011 | 10:09 PM
Krisx125's Avatar
Krisx125
HAHAHAH! I didnt realize that had to come out. i ALMOST machined down my flywheel.
Old Jun 1, 2011 | 06:08 AM
redman84's Avatar
redman84
I don't think you would have to look hard to get someone to do a swap with you.
Old Jun 1, 2011 | 03:47 PM
rodneywar's Avatar
rodneywar
i would do the swap anyday!!
Old Jun 1, 2011 | 03:53 PM
Jimmy Mac's Avatar
Jimmy Mac
I don't mind my 5 speed except that I have a hot spot on the fly wheel and get the chatter and bucking in reverse when I'm trying to back up either my camper or boat
It's just hard to feather the clutch and just can let it out all the way when backing into the storage unit
Is the 5 speed better than the auto
I did do the solid flywheel conversion and a nice southbend clutch but got it hot a few months later
Jim
Old Jun 1, 2011 | 04:19 PM
fordpride's Avatar
fordpride
if you do alot of towing then keep your 5speed
Old Jun 1, 2011 | 06:26 PM
427 fordman's Avatar
427 fordman
Auto works great for me pulling, and I love it, BUT, they are real expensive to rebuild if you buy a used one and have troubles. I agree with Mike, keep the 5spd, maybe just replace the clutch again if necessary. Lots cheaper.
jim collins
Aug 6, 2013 06:03 PM
gyrocopter1
1983 - 2012 Ranger & B-Series
Nov 28, 2012 11:42 AM
stainlessstroker95
17
Jun 12, 2012 09:13 PM
65-f100
Jul 16, 2005 07:03 AM
