conversions
Old Aug 20, 2010 | 07:08 AM
  #106
Brown Falcon's Avatar
Brown Falcon
Originally Posted by bostonpowerstroke
Hey,
I recently purchased a 1997 7.3 4X4 powerstroke that was converted from auto to manual.
After getting the steering column rebuilt the speedometer stopped working (dont know if it is related) but I also found out that the original wiring harness is still in place and is just tapped to accommodate the switch to manual.
I am also having an issue with a flickering alternator light and a delayed kick in of the alternator (when truck is started battery shows 8v then after about 30sec od driving clicks to 13v)
I was also told by seller that it has original auto ecu.
Dont know what I need to do? Replace wiring harness with manual specific harness? Change ECU?
Where would I get the parts, any instructions on the fix? Any recommendation for labor in the northeast?
Thanks in advance, Mark
The fueling is a bit different for the manual trans vs. the auto. A cheaper option than a new PCM would be to get a chip that's burned for a manual trans. That will override the auto programming and you can get one with 6 good custom tunes for under $400 from PHP, TW, Gearhead, or DP Tuner.
Do a seach in the forum for manual transmission swap, a member here did one a couple months ago and he knows what wiring needed to be changed and stuff...
Old Aug 20, 2010 | 01:44 PM
  #107
strokin'_tatsch's Avatar
strokin'_tatsch
I'd go to a junkyard and find a manual trans PCM rather than doing it though the chip myself. The main difference in fueling between the 2 PCMs is the bottom end. The manual trans will fuel when it sees load from a stop(example-letting off the clutch), the auto PCM won't do that.
Old Aug 28, 2010 | 07:53 PM
  #108
fordpride's Avatar
fordpride
So are you driving a CC yet?
Old Aug 28, 2010 | 07:58 PM
  #109
chicagodragon's Avatar
chicagodragon
not really. just got the IDI out today. i did the n cab wiring the other day, so that is one less thing to do. i wanna try and get the powerstroke in tomorrow, then the rest will be just wiring
Old Sep 2, 2010 | 04:14 PM
  #110
chicagodragon
Originally Posted by strokin'_tatsch
everything else on the truck should be the same. Only other thing I'd be worried about is the transmission wiring, but if that's not the same then it should swap over easily. the under hood wiring is actually kinda nice isn't it? it all comes out in one big chunk of wires and lays back in pretty nicely. Keep us updated on this thing
the tranny wiring is seperate from the rest of the harness and comes out seperatly.
Did you look to see if the towers on the frame for the motor mounts are the same?? I'm kinda curious. I don't think they are so you will have to torch out the rivets like i did on the F-150. Since your not going on a spending spree wanting a basically brand new truck you should get done in no time. I coulda had the F-150 running a year ago if i didn't want every dang part brand new. It's a sickness, i swear.
there is no difference in the engine mounts whatsoever
Old Sep 2, 2010 | 04:21 PM
  #111
chicagodragon
i got the engine and tranny in last night all in one shot, not fun. most of the wiring is done, just some little add ons for the back doors and third brake light ( cause we all know if the third brakelight dont work, the engine will leak oil). i hope to be driving by the end of the weekend if this stupid rain holds out.
my helper...
future powerstroke with the tool boxes on...
Old Sep 2, 2010 | 05:34 PM
  #112
fordpride's Avatar
fordpride
Glad to here it's going good.
So should i look at my 3rd brake light cause i can't find my oil leak LOL
Old Sep 2, 2010 | 05:38 PM
  #113
chicagodragon
That light can cause some weird problems
Old Sep 2, 2010 | 05:44 PM
  #114
427 fordman's Avatar
427 fordman
Looking good George. At least you have good help so you should be up and going soon!
Old Sep 2, 2010 | 06:29 PM
  #115
Brown Falcon
You putting the stacks on the dually?
Old Sep 2, 2010 | 06:55 PM
  #116
chicagodragon
Heck Yeah! I have a Good idea of how It will look, to. When they were parked next to each other I could see
Old Sep 2, 2010 | 07:17 PM
  #117
chicagodragon
Evan, if you had to do you conversion again, would you keep the 4:10 gears?
Old Sep 2, 2010 | 08:52 PM
  #118
fordpride's Avatar
fordpride
George having gone from the 3.55 to 4.10 i could not go back i still drive 70 on the interstate and i don't see a change in MPG. You thinking about swaping gears
Old Sep 2, 2010 | 09:17 PM
  #119
chicagodragon
It crossed my mind. Chris is loving the 355's, says he is getting way better mileage
Old Sep 2, 2010 | 10:19 PM
  #120
chicagodragon
Mike, When you and and the family coming down for a BBQ?
