conversions
Old Jul 8, 2010 | 05:47 PM
redman84's Avatar
redman84
There's a guy on PSN who did it. Just finished up. I'll see if he has a write up or anything on it. Pretty nice guy so he may offer some tips.
Old Jul 8, 2010 | 05:53 PM
chicagodragon's Avatar
chicagodragon
as it stands right now, iam torn between the '92 crew or a 96 crew. the 96 has a flatbed on it witch means it was prolly a cab chassis. arent the frames on a cab chassis differnt width than the regular frame, i want to put a regular bed on it.
Old Jul 8, 2010 | 05:58 PM
TheTowingCowboy's Avatar
TheTowingCowboy
Cab chassis = slimer frame. also F450 are slimmer frames.
Old Jul 8, 2010 | 05:59 PM
chicagodragon
i dont think it would be a big deal to mount a reg bed on it?
Old Jul 8, 2010 | 06:00 PM
TheTowingCowboy
But here is the thing I know alot of guys who put metal flat beds on there F350s (OBS's) so IDK if there would be a diffrence, plus the 96 would probably accept the engine easily, unless its a gasser that your going to convert to diesel. But if its a diesel you should have NO PORBLEM swapping.
Old Jul 8, 2010 | 06:01 PM
TheTowingCowboy
From my understanding you can mount a regular bed on them pretty easily just need to drill new holes. Also seen a guy fabricate 'TABS' for the bed.
Old Jul 8, 2010 | 06:03 PM
chicagodragon
i am leaning toward th 96. the engin is good, and a powerstroke=less work. i know ive read this,but arent the dually axels narrower? what about cab chassis axles?
Old Jul 8, 2010 | 06:06 PM
chicagodragon
this is the 96. 200k, and great interior.
Old Jul 8, 2010 | 06:07 PM
TheTowingCowboy
Cab chassis axles... I want to say are the same?
If I remember right there the same axle but spring perches are in different locations. Closer in.
Old Jul 23, 2010 | 11:14 PM
chicagodragon
i am moving back to the New Orleans area this thursday and will do the complete powerstroke swap into the 92 IDI. after iam done, all the IDI stuff and the 97 250 rolling body will be going up for sale. i will post in the classifieds when i am done. there are pics in my garage if you want to see. accessories such as stacks, toolboxes,etc... iam keeping. just a heads up.
Old Jul 24, 2010 | 10:05 AM
Dave Sponaugle's Avatar
Dave Sponaugle
Cab and chassis frame = 34" wide, left the factory as an incomplete vehicle, no bed installed, should only be found on an F350 vehicle
Pickup frame = 37.5" wide
A SRW axle and a cab and chassis axle are the same width back plate to back plate.
The narrower frame width sets the spring perches in farther, so you can run dual wheels on them.
A duallie axle, pickup body with fender flares installed from the factory on a 37.5" frame, is 4" wider back plate to back plate than a SRW axle.
Can't remember where I pulled these measurements at on the back plate,
53.75" SRW axle and DRW cab and chassis axle.
57.75" DRW duallie axle.
Old Jul 24, 2010 | 10:24 AM
chicagodragon
i ended up buying the 92. the one we were discussing in the IDI forum
Old Jul 24, 2010 | 11:53 AM
  #28
quesey's Avatar
quesey
if that dually has 3.54 gears in it. get with me on selling it.i'm ready to get rid of these 4.10s
Old Jul 24, 2010 | 11:56 AM
  #29
chicagodragon
I am keeping The dually
Old Jul 24, 2010 | 01:14 PM
  #30
chicagodragon
