conversions
Old Aug 19, 2010 | 09:13 PM
  #91
strokin'_tatsch's Avatar
strokin'_tatsch
Hope you don't have to have the 3rd brake light for anything. My F-150 was work a day, research for a week and order parts, work for a day, repeat. LOL
Old Aug 19, 2010 | 09:14 PM
  #92
fordpride's Avatar
fordpride
I just looked the motor mounts for both trucks and they do have the same part #'s
Old Aug 19, 2010 | 09:15 PM
  #93
chicagodragon's Avatar
chicagodragon
i was told the 3rd brakelight will screw with the cruise control. swapping it into the 92 will be easy, just need to extend the wires, its on the same harness as the rear speakers. its the door pin switches and locks getting to me now
Old Aug 19, 2010 | 09:16 PM
  #94
chicagodragon
that was easy.
Old Aug 19, 2010 | 09:18 PM
  #95
fordpride's Avatar
fordpride
Just one less thing to have to think about
Old Aug 19, 2010 | 09:20 PM
  #96
chicagodragon
i wasnt worried about that, if they are differnt, i can just pull em off the other truck. the damm locks are getting to me, iam gonna have to make a harness
Old Aug 19, 2010 | 09:22 PM
  #97
fordpride's Avatar
fordpride
That sounds like a PITA
Old Aug 19, 2010 | 09:23 PM
  #98
bostonpowerstroke's Avatar
bostonpowerstroke
Facing problems with 97 f250 powerstroke manual conversion
Hey,
I recently purchased a 1997 7.3 4X4 powerstroke that was converted from auto to manual.
After getting the steering column rebuilt the speedometer stopped working (dont know if it is related) but I also found out that the original wiring harness is still in place and is just tapped to accommodate the switch to manual.
I am also having an issue with a flickering alternator light and a delayed kick in of the alternator (when truck is started battery shows 8v then after about 30sec od driving clicks to 13v)
I was also told by seller that it has original auto ecu.
Dont know what I need to do? Replace wiring harness with manual specific harness? Change ECU?
Where would I get the parts, any instructions on the fix? Any recommendation for labor in the northeast?
Thanks in advance, Mark
  #99
chicagodragon
i dont think it will be that bad, if i find out that i dont need the 3rd brake light, things will be easier
Old Aug 19, 2010 | 09:25 PM
  #100
chicagodragon
the auto pcm will work with a manuel tranny. the alt will show low because the glow plugs are still drawing power after the wait light goes off
Old Aug 19, 2010 | 09:27 PM
  #101
chicagodragon
on the speedo, i cant think of anything other than the speed sensor, it has nothing to do with the column
Old Aug 19, 2010 | 09:28 PM
  #102
fordpride's Avatar
fordpride
On the 3rd brake light you need it i was having an issue with my trans shifting real hard and i when messsing with it one day i noticed my 3rd brake light was out change it and the hard shift went away/ sorry to bring such bad news
Old Aug 19, 2010 | 09:29 PM
  #103
fordpride's Avatar
fordpride
Originally Posted by bostonpowerstroke
Hey,
For your ALT light check all you grounds and batt cables
Old Aug 19, 2010 | 09:30 PM
  #104
chicagodragon
thats what i always thought about the light
Old Aug 19, 2010 | 09:32 PM
  #105
fordpride's Avatar
fordpride
I know that the crusie is all tied into the brake lights some how
