6.9 Tear down
Old Jul 7, 2010 | 01:27 AM
oreocreaming's Avatar
oreocreaming
i knew i seen them cheaper, but i only found the one set in my search.... damn ebay.
Old Jul 7, 2010 | 01:28 AM
David85's Avatar
David85
Yes, the front pulley needs to come off and you will need a puller to do it.
Old Jul 9, 2010 | 03:11 PM
Rick Wallace's Avatar
Rick Wallace
UPDATE.....I got the radiator out today,started on pulling heads,Is there a trick to getting the rear exaust manifold bolt out?? On the drivers side? All the others came out easy,a few turns with the ratchet then out with the fingers.Also,all the head bolts came out OK,The 2 in the very rear did not seem as tight as the others..Is this an indication of something? I got really POd at that last bolt so before I borrowed one of Joes hammers I decided to quit for today
Old Jul 9, 2010 | 03:16 PM
Otahyoni's Avatar
Otahyoni
I'd put anti-seize on everything you can when re-assembling. It has saved me huge headaches lots of times!
Old Jul 9, 2010 | 03:20 PM
Rick Wallace
Whoever did it last time did that,What I mean is I cant get a socket or wrench on it to get it out
Old Jul 9, 2010 | 03:23 PM
Otahyoni's Avatar
Otahyoni
I was just sayin.... let me go look at mine and see if i can think of something...
Old Jul 9, 2010 | 03:28 PM
Rick Wallace
thanks..
oreocreaming
get a couple extentions and get to it from the fender well behind that splash guard. Makes it a ton easier
Old Jul 9, 2010 | 03:31 PM
Otahyoni's Avatar
Otahyoni
I looked at mine, and i can't even get my finger on the bolt... if you're using a cherry picker, i thought i'd read about someone pulling the heads with manifolds attached...
I need new valve cover gaskets...
Old Jul 9, 2010 | 03:32 PM
Rick Wallace
You see why I surround myself with smart people??? Why didnt I think of that...JEEZZ I guess my noggin is getting soft,,After this monster Thunderstorm goes thru ill try it...
Old Jul 9, 2010 | 03:34 PM
Rick Wallace
No cherry picker,I got to do it the old fashion shade tree method..
Old Jul 9, 2010 | 03:42 PM
Otahyoni's Avatar
Otahyoni
When i looked at mine, i could get all but the very last that way, but there's no way i'd get on the very last one... it's a 1/4" from the firewall...
Old Jul 9, 2010 | 06:47 PM
  #28
Dave Sponaugle's Avatar
Dave Sponaugle
Rick you also have to pull the first oil pan bolt on each side of the crankshaft when you pull the front cover.
Oil from the CDR has a way of going mostly to the #7 and #8 cylinders.
So the extra BTU's from the oil burning along with the fuel, make the cylinder pressures highest in the rear cylinders of each head.
That over time stretches the rear head bolts, and will eventually cause head gasket failure.
When they stretch, they appear to be looser when you pull them out.
Old Jul 9, 2010 | 11:28 PM
  #29
Rick Wallace
Thanks Dave,that makes sense to me,Is there a problem reusing the head bolts when I go back together? Im thinking about less $$ but I want it to be right.
Old Jul 10, 2010 | 12:06 AM
  #30
oreocreaming
just gotta make sure they arent over stretched.
