new tires!
Old Jul 13, 2010 | 07:23 PM
  #46
cpetersen's Avatar
cpetersen
i have no idea wat front end i have
Old Jul 13, 2010 | 07:31 PM
  #47
Coalroller's Avatar
Coalroller
the 250's had the ttb front end unless someone changed it out with a dana 60 straight axle if im not mistaken
Old Jul 13, 2010 | 07:37 PM
  #48
oreocreaming's Avatar
oreocreaming
if you have the regular cab, then its the ttb dana 44, if its the extended cab or crew cab then its the ttb dana 50
Old Jul 13, 2010 | 07:41 PM
  #49
Coalroller's Avatar
Coalroller
on the sky site it says itll fit the 250's as well but i would call just to verify that it does fit
Old Jul 13, 2010 | 07:45 PM
  #50
cpetersen's Avatar
cpetersen
its regular cab so coalroller on that site was i lookin for the shackles? or wat im kinda lost and how many leafs would i have to do to fit these tires?
Old Jul 13, 2010 | 07:46 PM
  #51
oreocreaming
the f250 and f350 is the same exact lift kits.
Old Jul 13, 2010 | 07:49 PM
  #52
oreocreaming
you cant do a shackle lift on the front of any truck. you can do a shackle reversal kit, runs about $700 bucks. you have the option of either 2.5" or 5" lift. you would need 3 leafs but dont do that man. just buy a full leaf kit. just cause its cheap doesnt mean its right. Summit Racing - High Performance Car and Truck Parts l 800-230-3030 you can get the leafs there for as good of a price as anywhere.
Old Jul 13, 2010 | 07:50 PM
  #53
mabc926's Avatar
mabc926
I don't want to sound rude or anything....but maybe you should get to know your truck a little better before you start trying to make plans for it, it will save you alot of headache down the road........as for the tires and fitting them on your truck, I've been told 37's will fit on a stock truck...so adding one leaf should give you enough room.
Old Jul 13, 2010 | 07:51 PM
  #54
Coalroller's Avatar
Coalroller
its a shackle reversal kit, it will move your front shackles that are located within the frame right behind the front bumper to the rear of the spring pack and makes the stationary point in the front just like the 99-c super dutys are now it allows for a smoother ride, its on page 6 of the site under products or if you just wanted to do the add-a-leaf id say 3 maybe you get away with 3 in the front will give you the amount of lift to get 37's but dont forget to do the rear, not as many leafs are needed for the rear tho being as it should already be higher than the front, sorry for the confusion bud im not real good at explaining things unless i have pictures haha
Old Jul 13, 2010 | 07:52 PM
  #55
cpetersen's Avatar
cpetersen
ok so i cant just put some leafs on and call it good? or i have to buy a lift kit? if i can i would much rather do the $70 per axle you said oreo thats alot cheaper than then a 650 lift kit
  #56
oreocreaming
you can not fit 37's on a stocker. i had 37's with a 4" lift and it still would rub the fenders a little.
Old Jul 13, 2010 | 07:53 PM
  #57
Coalroller's Avatar
Coalroller
when you get to adding more than 2 leafs it gets to be a really rough ride though, the only reason i did is for the snow plow weight that will be goin on this fall plus i had the springs layin around from a friends truck
Old Jul 13, 2010 | 07:54 PM
  #58
mabc926's Avatar
mabc926
Wanna bet on that?
Old Jul 13, 2010 | 07:55 PM
  #59
Coalroller's Avatar
Coalroller
oreo is right plus his is only a 250 so its shorter yet
Old Jul 13, 2010 | 07:57 PM
  #60
mabc926's Avatar
mabc926
Check this guys truck out.
Oilburners.net
all stock
