Check Engine Light - P0113
Old Jul 4, 2010 | 10:36 AM
BRNZY's Avatar
BRNZY
Hello,
I just signed up here from another F150 forum and was hoping I could get a little help. I have a code P0113 that I have had cleared and keeps coming back. I have already replaced the MAF (which has the air charge sensor built into it), and also recently had to replace the fuse block. The code is stating that the air intake temp is minus 40 degrees. Any suggestions as to what else could cause this? Any help would be appreciated.
Old Jul 4, 2010 | 10:56 AM
shotgunz's Avatar
shotgunz
Do or did you have any performance modifications?
Old Jul 4, 2010 | 11:19 AM
BRNZY's Avatar
BRNZY
I did have what was supposed to increase MPG and horsepower. It was wired to the harness that goes to the MAF. I had a problem with my fuseblock the other day that caused me to have to replace it. The check engine light was never there until after the fuseblock was replaced. I was told it was a bad MAF. I replaced that and the pigtail harness to it after removing this part that I added to it. Now I am afraid that I have a problem within the PCM?
Old Jul 4, 2010 | 11:27 AM
shotgunz's Avatar
shotgunz
Was it one of the $20 Chips (or similar) from eBay (50 hp, 100 ft-lb, and 25% mileage increase) (actually a $.10 resistor in a fancy package)?
If so, yes, it's VERY possible you have fried the PCM's analog input for the MAF.
You have a couple of choices. Take it to the dealer. Or get a repair manual (or DVD) and try to troubleshoot it yourself.
Old Jul 4, 2010 | 11:37 AM
BRNZY's Avatar
BRNZY
I feared that I may have infact damaged the PCM. Yes the Ebay item was similar. Odd thing is, I have had it installed for several weeks and no issues. I was installing a kill switch and in error grounded out a circuit and fried the fuse block! Fuse block is replaced and now a CEL? I do have a repair manual and am getting ready to drive to San Diego from Phx. I do not want to have the CEL on the whole time in case something else goes wrong and I will not know it. I am trying to find a PCM at a salvage yard and get flashed. But cannot find one. That of course, with hopes that is the problem.
Old Jul 4, 2010 | 02:04 PM
bridge's Avatar
bridge
Sick 'n Tired
Man, I hate to see that. Another one of those Ebay resistors claims another victim. That code is usually caused (without modifications mind you) by a bad harness/short. The max is 4.6 volts. Give you're wiring job from when you replaced the pigtail another once over and make sure you don't have a short. Also, unhook your battery and step on your brake to completely discharge the system. Best of luck to you...
jdgrier05
Jul 24, 2016 01:21 PM
blueline970
Feb 19, 2016 12:12 PM
The Solar Guy
Mar 25, 2015 01:45 PM
BOBB13Bs
Jul 28, 2011 04:19 PM
itsotto
Oct 4, 2010 02:13 PM
