1997 7.3 PSD No Start, Numerous Codes
Old Apr 20, 2012 | 09:37 PM
The Solar Guy's Avatar
The Solar Guy
Greetings all. Have an E350 ambulance,just completed a 10K round trip to Belize with no problems, truck would not start on 2nd day back. AE is displaying two sets of codes:
KOEO Test:
P0113 Intake air temp high
P1212 ICP Low
P1283 IPR Control Circuit
P1293/P1294 Injector High Side Open (both banks)
Codes when cranking:
P0472 Exhaust pressure low
P1212 ICP Low
P1280 ICPSensor circuit
P1396 GP Monitor fault (bank 2)
So far, replaced CPS and IDM as I had spares of both. No change. Cranking RPM 175. GP system working fine. Oil in ICP sensor connector, still no start when disconnected ( have new sensor on order). No SES light (except when ICP sensor disconn). HPOP reservoir full. Engine Oil pressure solid. Batts....all 4 fully charged. Good fuel pressure at check valve. All filters new.
There is no smoke or fuel smell while cranking.
I think that about does it for where Im sitting at this point.
I do have intake tubing off and wiring disconn, likely accounts for the P0113.
Have been searching the forum and thank everyone for all the advice that"s gotten me this far, but I am stumped as haven"t seen any combination of codes like this. Should I be looking further into the HPO system or am I looking at possible PCM probs? Thanks!
Old Apr 20, 2012 | 10:04 PM
JamesHajek's Avatar
JamesHajek
Since you have AE, get the data for ICP psi and DC% while cranking... That will tell you whether it's an oil issue or not.. You need at least 500psi to start...
Old Apr 20, 2012 | 10:29 PM
pjwoolw's Avatar
pjwoolw
I'd take a look at the harnesses. Connector to the PCM etc. Thats a bunch of codes.
Are you in California?
Old Apr 20, 2012 | 11:19 PM
The Solar Guy
In AZ. Took a look at all suggested areas there could be chafing or shorts, didn't come up with anything obvious. Will run AE scan with meters tomorrow.
Old Apr 20, 2012 | 11:48 PM
redman84's Avatar
redman84
Did you get the rpm reading from AE or where?
Old Apr 21, 2012 | 12:26 AM
oldbird1965's Avatar
oldbird1965
Ya, rpm's need to be 200 to start. You might need a new starter, regardless if it tests good. The 0113 is confusing, pulling hard I've seen mine at 186*, I wonder how high it has to go to set a code.
Old Apr 21, 2012 | 06:05 AM
427 fordman's Avatar
427 fordman
Maybe a sticky ipr, these would be numbers nice to see.
Old Mar 25, 2015 | 01:26 PM
Ronaldmansfield141's Avatar
Ronaldmansfield141
What's an AE?
It must be a tester of some kind?
Old Mar 25, 2015 | 01:45 PM
oldbird1965
Auto Enginuity, it can run data logging, check codes, reset codes and do tests.
tidexp
23
Sep 9, 2012 08:37 PM
agg_bagg
Aug 3, 2011 10:36 AM
Roadgrinder
63
May 6, 2009 01:53 PM
totin_tools
Mar 23, 2008 09:52 AM
Easy
13
Dec 20, 2006 08:18 AM
