HELP- Pyro Install
Old Jul 4, 2010 | 09:08 AM
TxFordGuy's Avatar
TxFordGuy
HELP- Pyro Install
Need some advice. i just finished drilling and tapping my hole for the pyro. i have been following the following guide (Gauge Install). Well i didn't bother to recheck the actual size of my pyro as to what he installed. The directions didn't include a size. the only place i found my size(after the fact) was on the page where i bought it at dieselmanor. well guess what. i drill and tapped the whole to 1/4" instaed of 1/8". What do i do now? plug and redrill? try and find an adapter? and would an adapter have to be special for high heat? HELP HELP HELP
Old Jul 4, 2010 | 09:58 AM
arcticatdan's Avatar
arcticatdan
Iwould think a stainless adapter would work fine.
Old Jul 4, 2010 | 10:12 AM
kccatpower's Avatar
kccatpower
i agree with using an adaptor
Old Jul 4, 2010 | 11:31 AM
HKusp's Avatar
HKusp
Stainless or brass adapter. I would prefer brass myself. It's nice and soft and will conform better to the threads. Any good hardware store should have an assortment.
Old Jul 4, 2010 | 11:57 AM
TxFordGuy's Avatar
TxFordGuy
will brass hold up to the tempature or melt?? i looked it up and it shows the melting point at 1652 degrees. I know the exhaust shouldn't get over 1200 degrees. but is that just the gas that gets that hot or the manifold as well?
Old Jul 4, 2010 | 12:14 PM
big poppa's Avatar
big poppa
Brass would work but SS or equivalent would be my choice. I'm suprised, I got my gauges from Diesel Manor(before Clay was in business) and their directions that came with my kit were great.
Old Jul 4, 2010 | 12:24 PM
twags6's Avatar
twags6
The manifold will get hot, but not as hot as the gas, especially if you're just doing a few seconds worth of temps above 1200.
Old Jul 4, 2010 | 08:57 PM
TxFordGuy's Avatar
TxFordGuy
Well i got lucky in finding the bushing since all the hardware stores around were closed. there was an adapter with the tranny that worked perfectly. got everything up and going now. gauges look awesome. thanks for the advise
off main topic. what kind of boost numbers should i see? just a quick dry run i saw 16lbs stock and 26lbs with 80e on.
Old Jul 4, 2010 | 09:12 PM
Bob Taulbee's Avatar
Bob Taulbee
Duct Tape Tech.
Those numbers are about normal. I get 18 stock and 28 in 80e.
Old Jul 4, 2010 | 11:04 PM
big poppa's Avatar
big poppa
I max my gauge out at 30 PSI's in 80E and it probably goes higher but your numbers sound good. If you want to get a little bit more boost, get yourself a boost fooler, it will stop your truck from defueling at higher RPM's and in turn yield you more boost.
KJNDIVER
Apr 13, 2014 02:59 PM
Joelong258
Feb 21, 2011 02:54 PM
HH60FE
15
Sep 19, 2010 12:58 AM
highboy390fe
Feb 24, 2008 04:47 PM
Fxehogg1
May 13, 2007 03:24 PM
