Pyro install?
Old Feb 21, 2011 | 01:38 PM
Joelong258's Avatar
Joelong258
Pyro install?
What size tap do you use for a autometer pyro probe after you drill the hole?
Old Feb 21, 2011 | 01:42 PM
woodnthings's Avatar
woodnthings
Most common is 1/8"-27 NPT. The hole size is 11/32" or letter R bit.
Old Feb 21, 2011 | 02:10 PM
JOHN2001's Avatar
JOHN2001
^^^^^^Ill second that ^^^^^^^
Old Feb 21, 2011 | 02:54 PM
clintbonnie's Avatar
clintbonnie
Be real careful when you are taping the hole.. If you go too deep with the pipe tap, you will have a oversize threaded hole and your fitting will not tighten up... Tap shallow and try the fitting.. repeat until you get the proper fit..
Insley95
Jul 28, 2011 02:53 PM
06 Beast
Feb 7, 2009 12:27 PM
adam red 351
16
Nov 17, 2005 08:40 AM
Tha50Kid
Feb 15, 2005 09:41 PM
PSD6litre40
Jul 29, 2004 06:02 PM
