VIN DECODING
Old Jun 30, 2010 | 10:30 PM
smokethisfocus's Avatar
smokethisfocus
VIN DECODING
I have a 1976 Ford F-1-- (not sure) I think its the camper special. VIN is F13MRD04047, W.B-133, Color-IM, G.V.W.-F130, Body-BBA, Trans-G, Axle-38J Anyone help me out here?
Old Jun 30, 2010 | 10:35 PM
sniper250's Avatar
sniper250
Your Model Year is August 1976.
Truck Series: Unknown, Please double check VIN number
Engine: V8 - 390cid, 4BBL carb
Assembly on: San Jose, CA
Old Jul 1, 2010 | 01:21 AM
mikeo0o0o0's Avatar
mikeo0o0o0
F13= Not listed
M= 390 cu in 4bbl V8 engine
R= San Jose Assy. Plant
D04047= 1976 sequential serial number
WB 133= 133" wheelbase
Color IM= (I) bright medium blue metallic (M) white
GVW not listed= Gross vehicle weight
Model F130= Not listed
Body BBA=(BB) Blue all vinyl interior (A)Not listed
Trans G= Automatic transmission
Axle 38J= (38) 3.73 non-locking 5300 lb capacity Dana 60 (J) with power steering
You have quite an interesting warranty tag. The series F13 and model F130 aren't listed, neither is the back of cab equipment (the A in BBA) this is whether its a styleside, flareside, etc. Then the real interesting one, (38) indicates a Dana 60 rear. This is for an F250 3/4 ton. If it was an F250 the VIN should start with F25 of F26 and model should be F2xx. Interesting.
All of my info is from the 1973/79 series 100/500 Master Parts and Accessories catalog from Ford
Old Jul 1, 2010 | 08:25 PM
merccougar93's Avatar
merccougar93
OK, i could use a little help with mine:
F37ZCEF0011
F37-F350 CAB AND CHASSIS 4X2
Z-?? I THINK ITS A 351W, ITS GOT 6 BOLT VALVE COVERS.
C- ONTARIO PLANT
EF0011- SERIAL NUMBER
BUT I COULDNT FIND A LISTING FOR MOTOR CODE Z ON ANY DECODER I HAVE SEEN.
Old Jul 1, 2010 | 09:10 PM
mikeo0o0o0's Avatar
mikeo0o0o0
F37= F350 2WD cab & chassis
Z= Domestic special order -That's all the chart says
C= Ontario truck plant
EF0011= 1979 model year sequential serial number
This information is from the Ford parts catalog
Old Jul 1, 2010 | 09:31 PM
merccougar93
ok, that explains alot. it used to be an old uhaul truck, but its got an akward thermostat housing like ive never seen. ive got the hose coming from the radiator going to some kind "router" is the best word i can use to describe it. Its looks kinda like a brick with a hose coming out of it going to the water pump, and from the top of the router it goes to the thermostat housing going into the intake manifold through the front, not through the top<-- just noticed that. I was thinking it was a 351w until then, but now im not sure.
Old Jul 2, 2010 | 11:36 AM
mikeo0o0o0's Avatar
mikeo0o0o0
If you can post some pictures, maybe we can help.
By any chance is the emission certification sticker still on the valve cover?
That would have the engine info on it.
Old Jul 2, 2010 | 12:41 PM
merccougar93
only sticker there that remains is: crankcase capacity- 5.8L
Old Jul 2, 2010 | 02:18 PM
76f350spercamprspeal's Avatar
Your VIN is:
F37ZCEF0011.
F37= F-350 Cab & Chassis, Two Wheel Drive.
Z= D.S.O. Engine (Special Order) (District Sales Office) (I don't have my Catalog with me..)
C= Ontario, Canada Plant Assembly Line.
EF0011= '79 Build Sequence Number Thingy.
Your Truck was Built in February of '79, Makin' it a '79 Model Year.
Welcome to FTE, Best Damn Forum EVER!
Here's How to Post Pictures: (You can't Directly add 'em Cause you don't have 25 Posts)
1. Login to FTE.
2.Click User CP (In the Top Left Hand Corner)
3.(On the Left, There will be a list, The 5th Option Down, will say "Pictures & Albums) Click That.
4.Then, Click Add Album, Enter a title, and description, if ya want to.
5. Click Upload Pictures, Then click Browse, Locate the Files of your '79 (You can add 3 files at a time)
5. Click Upload.
6. Add a description to the individual pictures, then click save.
7. Add more files if ya want.
8. Click The Picture you want to post, it will give you two codes at the bottom, Right Click The Second one (It say's BB Code, Then Say's [IMG]http:blahblahblah...[/IMG])
Then, Once that is highlighted, Right Click, Then Copy, Then Paste it into your post.
You can add up to 30 Images in one FTE Post.
If, Ya need any help, Don't hesitate to ask.
Old Jul 2, 2010 | 02:26 PM
merccougar93
right now i dont have a camera for pictures, but im trin to upload pics form my phone
Old Jul 2, 2010 | 02:29 PM
E-Mail them to Me, I will post 'em up.
saxzootsims at aol.com (Replace at with @) No Spaces, No Caps, Tell me when they are sent.
Old Jul 2, 2010 | 02:33 PM
merccougar93
if i can get them on the comp, i can do it, but it depends on how my phone wants to be
Old Jul 2, 2010 | 02:35 PM
Then Text them to me. (909)-567-4891
Old Jul 2, 2010 | 02:44 PM
merccougar93
OK HERES 1:
(7) (8)
(5) (6)
(3) (4)
(1) (2) Im not sure if thats the cylinder order, but this is my firing order based on that:
1,2,7,3,4,5,6,8
Old Jul 2, 2010 | 04:20 PM
mikeo0o0o0's Avatar
mikeo0o0o0
That engine is an FE/FT series, I would say FT because of the water pump and thermostat housing. Probably a 361 based on the 5.8L. I didn't think they were put in after '76.
Do you know if that's the original engine?
