Shutter and 1211 codes
Old Aug 13, 2010 | 03:26 PM
  #31
resilent's Avatar
resilent
OK whats the lpop sorry i don't know that one.
Old Aug 14, 2010 | 03:54 AM
  #32
Visseroth's Avatar
Visseroth
low pressure oil pump
Old Aug 14, 2010 | 01:13 PM
  #33
resilent's Avatar
resilent
I had it scanned again the ICP drops under acceleration, what would cause that. Mechanic said check map sensor and line and could be a turbo issue.
Old Aug 14, 2010 | 07:46 PM
  #34
Visseroth's Avatar
Visseroth
ICP and the Map and different entities, If the ICP drops under WOP then you could have a bad IPR which controls your HPOP pressure and duty cycle.
Old Aug 23, 2010 | 12:05 PM
  #35
resilent's Avatar
resilent
IPR is brand new.
Old Aug 24, 2010 | 02:57 AM
  #36
Visseroth's Avatar
Visseroth
Have you tried unplugging the ICP?
Old Aug 25, 2010 | 09:34 AM
  #37
resilent's Avatar
resilent
Yes, I did this initially. The sensor is new. It had oil in the plug. New harnes also, I did one wire at a time not to cross them up.
I finally gave in and took it to the shop. I have no word yet what the problem is. I am still leaning towards hpop.
Old Aug 25, 2010 | 02:46 PM
  #38
Visseroth's Avatar
Visseroth
Yea, sorry, wish we could help more. Let us know what the results were.
Old Aug 27, 2010 | 06:58 PM
  #39
resilent's Avatar
resilent
OK got the truck back from the shop, he gave me the choice to work on what the main problem was, the fuel pump was junk. I had put the walbro on when this first started but I had the stiffer spring in the regulator and could have fried both pumps. I also have a main harness and injector harness issue to address also.
I did tje new airtex pump today, but I have not driven it much to load up on it. I hope this is the fix.
Old Aug 27, 2010 | 09:26 PM
  #40
Visseroth's Avatar
Visseroth
wow, well let us know how it turns out!
Old Aug 29, 2010 | 12:12 PM
  #41
resilent's Avatar
resilent
So far so good, I was hitting the hills and the roads that it used to act up on and its not duplicating the problem. I still need to address the harness issue, but its running so off to a good start.
brandonrr
Feb 29, 2016 05:20 PM
Slyhuntr
May 15, 2015 02:00 PM
cptaylor
Feb 10, 2015 12:46 PM
rockstate45
24
Jan 15, 2008 02:06 PM
fisherj
Oct 2, 2007 05:09 PM
