Points
Old Jun 28, 2010 | 01:44 PM
79FordBlake's Avatar
79FordBlake
Points
I changed the oil in my 73 today and figured while it was inside the garage I would check the point gap.
Well I found out they were pitted pretty good. So I took them out and filed them off good and the pits cleaned up alright. Put them back in and adjusted them and truck runs better.
I put the points in at 52,000 miles and it now has 57,358 miles. What would cause the pitting already, cheap points? Thanks.
Old Jun 28, 2010 | 01:52 PM
mikeo0o0o0's Avatar
mikeo0o0o0
5000 miles on a set of points isn't bad. Ford used to recomend tune ups every 4,000 miles(!!!). Excess metal transfer between contact surfaces is an indicator that the condenser isn't the correct capacitance. IIRC metal build up on the ground side meant the condenser capacitance was low, build up on the moveable contact meant the capacitance was high.
Pitting was just a sign of use.
Starting to shake the cobwebs out on that one.
Old Jun 28, 2010 | 08:13 PM
fmc400's Avatar
fmc400
MSEE
Excess wear on the points could mean the condensor is letting the points arc; it's also a sign they were gapped too closely. To agree with Mike even more, that's not all that bad for points with that much mileage. There's a reason they're ancient.
Old Jun 28, 2010 | 09:30 PM
79FordBlake
Thanks guys, I was just thinking that might have been excessive wear b/c I have many old tractors that only God knows how many hours are on a set of points.
BlackGold1955F100
Feb 24, 2013 07:43 PM
xc4jokestomper
Dec 22, 2011 02:29 PM
thendrix
Sep 30, 2008 03:43 PM
Fair 96
Paint & Bodywork
Apr 28, 2006 11:12 PM
EgoMan
27
Jul 17, 2005 06:50 PM
