Header bolts
Old Jun 30, 2010 | 04:37 PM
  #61
darthice's Avatar
darthice
Lew did you have to change your pushrods to put the dooe heads in or did you just bolt the in?
Old Jul 1, 2010 | 10:30 AM
  #62
darthice's Avatar
darthice
Ok so asap i am going to be getting the gaskets and stuff to swap the heads out the heads on the other engine are pre 74 because they do not have smog ports on them. I will let you guys know of the progress.
Old Jul 1, 2010 | 10:53 AM
  #63
nstueve's Avatar
nstueve
take pics so we can see and others will know the answer in the future. Did you get a number from the heads so we could date them? I am curious as to what year they are... kinda like an itch you can't help but scratch...
Old Jul 1, 2010 | 11:00 AM
  #64
darthice's Avatar
darthice
Well its interesting i am sure they are d0oe heads because of no smog ports anywhere on them they are on a D4CE Engine so i am thinking they are the last generation D0OE gotta pull the intake and the heads to be sure though i couldnt find the casting number anywhere on the outside so...
Old Jul 1, 2010 | 11:11 AM
  #65
nstueve's Avatar
nstueve
Here... I just found this and you might find very useful information about D0oE heads in it. It sounds like they take a spark plug design that is becoming rare to find a cool 18mm... Maybe something to consider...
How good are 351 D0OE heads ? - Corral.net : Ford Mustang Forums
Old Jul 1, 2010 | 11:17 AM
  #66
darthice's Avatar
darthice
well i could always drill the spark plug holes and tap them to accept a the same size as the e7te heads
Old Jul 1, 2010 | 11:23 AM
  #67
darthice's Avatar
darthice
or put a sleeve in there cause i just remembered that the hole is smaller for the newer heads
Old Jul 1, 2010 | 11:29 AM
  #68
lew52's Avatar
lew52
....Mine had screw in studs , adjustable valves , i used hardened push rods & guild plates , as far as the spark plugs go i used the big autolite plugs .....Lew
Old Jul 1, 2010 | 11:48 AM
  #69
darthice's Avatar
darthice
yeah i just saw oriellys has them for cheap i will just get 8 of those.
Old Jul 1, 2010 | 12:41 PM
  #70
darthice's Avatar
darthice
lew did you have to get hardened valve seats put in those heads of yours
Old Jul 1, 2010 | 12:44 PM
  #71
lew52's Avatar
lew52
The hardened valve seats & new valves were put in before i got them....
Old Jul 1, 2010 | 12:51 PM
  #72
darthice's Avatar
darthice
AHH Ok well i got these second hand also and it does have new valves in em
Old Jul 1, 2010 | 01:29 PM
  #73
lew52's Avatar
lew52
Yeah , nobody throws these old heads away , there not bad heads , especially when someone else put the money in them . When i go aluminum i will find a good home for them ....
Old Jul 1, 2010 | 01:32 PM
  #74
darthice's Avatar
darthice
i know i have seen guys have these heads repaired after cracking just to keep the heads.
Old Jul 6, 2010 | 09:31 AM
  #75
darthice's Avatar
darthice
yea i found out one of the heads is a D0OE and one is a D5TE-EB they both look exactly the same aside from the spark plug sizes
