Header bolts
Old Jun 28, 2010 | 02:41 PM
nstueve's Avatar
nstueve
yes starting the engine and getting it hot will draw the pb blaster down the threads a little... I have also ran it hot and shot it with pb while running and then held a piece of dry ice to the bolt to cool just the bolt. Molecules in bolt shrink and make it smaller and the heat from engine makes the threaded hole a little bigger... Then try torquing it off. remember back and fourth pressure on the bolt to break it free... if it comes loose a little i usually hit it with pb and screw it in and out a couple times to make sure it won't get stuck again while trying to take it out. Works the rust loose and the pb into the threads... back and fourth is the key though...
Old Jun 28, 2010 | 02:51 PM
zxwut?'s Avatar
zxwut?
Lots of patience.
Old Jun 28, 2010 | 02:53 PM
darthice's Avatar
darthice
ok cool will an acetylene torch heat it up too much my boss has one will that help with removal.
Old Jun 28, 2010 | 03:02 PM
darthice's Avatar
darthice
yeah i think my buddy got into a hurry trying to get the studs out and broke them off now i gotta fix them but hey i was figuring some would break.
zxwut?'s Avatar
zxwut?
I wouldn't go that extreme.
Old Jun 28, 2010 | 03:14 PM
darthice's Avatar
darthice
Ok i will do the get the engine to operating temp and cool them with dry ice. I was wondering if i can do it with the headers off will it mess up the engine to run it without them?
Old Jun 28, 2010 | 03:21 PM
nstueve's Avatar
nstueve
i figured you were doing this with the headers off... wear hearing protection! It will be loud as hell! but shouldn't hurt any thing...
Old Jun 28, 2010 | 03:30 PM
darthice's Avatar
darthice
ok i didnt think it would unless it was in the middle of winter lol
Old Jun 28, 2010 | 03:37 PM
lew52's Avatar
lew52
Its not the noise so much as the flames its going to shoot out , will be cool at night....Lew
Old Jun 28, 2010 | 03:44 PM
darthice's Avatar
darthice
yea that will be cool i may do it at night if the misquitos arent too bad
Old Jun 28, 2010 | 04:05 PM
lew52's Avatar
lew52
Keep a fire extinguisher handy ....
Old Jun 28, 2010 | 04:12 PM
darthice's Avatar
darthice
I always keep a fire extinguisher handy lol i have this problem with things catching fire when there isnt even anything flammable around lol
Old Jun 28, 2010 | 04:37 PM
  #28
darthice's Avatar
darthice
any of you ever use freeze off penetrating oil by crc industries. I heard it is awesome at cooling the bolt down and getting the oil down in there
Old Jun 29, 2010 | 04:52 PM
  #29
darthice's Avatar
darthice
i guess no one has used the stuff lol i saw it on the shelf at ORiellys and thought it would be worth a shot.
Old Jun 29, 2010 | 05:02 PM
  #30
Old93junk's Avatar
Old93junk
STOP!!!!........STEP AWAY FROM THE TRUCK!....
You broke off 8 of 16 exhaust manifold bolts?
At this point, to preserve my knuckles and sanity, I would just take the intake off and pull the heads. Take the heads to a machine shop and get the bolts out without damaging anything, you can inspect the heads and valves, get a look down in the comb. chambers. Throw on a set of new head gaskets and intake gasket and you are actually ahead of the game for a few years down the road!
