I know this is the F-150 forum, but I figured I try here as well as the Expedition forum.
2006 Expedition with 73000 miles. Just started hearing a whistle-type sound from the tranny area when the truck is in gear, forward or reverse. Seems to tune itself with engine RPMs versus highway speed. Can't hear the noise in park or neutral. Tranny shifts fine, no jerking, no slipping, nothing besides the "noise". If not for the noise, I wouldn't even think anything is wrong. Been doing it for about a week.
Any ideas? Other info I've read on-line seems to suggest torque converter. I was planning on getting rid of it soon anyway (nickle-dime stuff is killing me!), so I may just turn on the air and turn the radio on low when I trade it in. If you didn't know any better, someone might actually think it's normal.
If I were to fix it (assuming it is torque converter), any idea what it costs to replace at a shop? I believe tranny has to be R and R'd to complete job. Would this be a good time to replace a flywheel as well? I get the dreaded starter grind every now and then that a new starter didn't fix (though it did make the problem a lot less frequent). I figure if the flywheel is dinged, might as well do that at the same time.
