My motor moved!!!!!
Old Jun 27, 2010 | 01:21 PM
superpony18's Avatar
superpony18
My motor moved!!!!!
For a while now when I would be on uneven terrain I could here the fan making contact with the shroud. When I was on the way home the other day the fan took out the hose that goes from the bottom of the reservoir-radiator. Upon further inspection the fan has been rubbing for a while The fan is actually through the shroud by about 1/6" on the right, leaving about a 1/4" of space from the hose, and about an 1.5" on the other side.
I'm thinking motor mounts does that sound right? Any help is great, have a good Sunday.
Old Jun 27, 2010 | 01:29 PM
SpringerPop's Avatar
SpringerPop
I THOUGHT these has interlocking motor mounts, but I've never looked at them carefully.
This is the first report of this kind of failure that I can remember hearing about.
Some guys make LOTS of torque without these breaking.
Pop
Old Jun 27, 2010 | 01:42 PM
superpony18
To my untrained eye I actually don't see any reason for this to happen. The motor mounts look fine (as best i can see), radiator didn't move. I parked the truck, put in gear, held brake, and gave it some throttle. The motor does move maybe a half inch or so. Is that excessive?
A side note my clutch fan is frozen.
Old Jun 27, 2010 | 02:03 PM
zx250's Avatar
zx250
Of the next Riffraff East
I doubt the motor has moved, more likely something else shifted. Maybe the shroud itself? Ever had front end damage? I'm with Pop, never heard of a mount breaking.
Old Jun 27, 2010 | 02:16 PM
SpringerPop
A half-inch is not excessive.
The frozen clutch won't cost you anything but some gas mileage.
I'm with Barry on the shroud moving.
Are the hoses original? Might someone have replaced them with hoses that are routed too close to the fan?
Pop
Old Jun 27, 2010 | 02:18 PM
superpony18
I believe before I got the truck it was in some kind of accident, but that was over 4 years ago. there is a bit of room on the driver side of the motor and I can't fit my hand between the right valve cover and the ac. the radiator and shroud are both firmly in place.
Old Jun 27, 2010 | 02:23 PM
SpringerPop
If the truck was in an accident, is the frame straight? The front end or the frame doesn't veer to one side, does it? That would allow the front-end sheet metal and core support to be off-center, whereas the motor mount locations may still be centered. That would have the fan off-center in the shroud, along with everything else in the front end.
Crawl underneath and verify the transmission mounting point is secure. If the rear breaks it could allow the entire assembly to twist sideways, and it will be most accentuated in the rear and fan areas, and stress the side motor mounts.
Pop
Old Jun 27, 2010 | 02:27 PM
superpony18
I understand what you are saying, but wouldn't it have shown up before now?
Old Jun 27, 2010 | 02:31 PM
SpringerPop
Not if the transmission mount just broke recently.
Pop
Old Jun 27, 2010 | 03:00 PM
farmb0y's Avatar
farmb0y
Could the water pump be out, allowing the fan to be contacting the shroud? I wouldn't think you would be able to run for very long with it out, but it's something to check.
Old Jun 27, 2010 | 03:05 PM
superpony18
coolant temp is normal. Taking more measurements.
Old Jun 27, 2010 | 03:36 PM
superpony18
Having difficulty taking measurements by myself. Just standing/laying there staring at the truck it looks like the motor is sitting to the passenger side. I can not find any evidence that anything has moved, except for the fan through the fan shroud on the passenger side.
Old Jun 27, 2010 | 04:08 PM
farmdad's Avatar
farmdad
This thread shows what can happen when the fan clutch freezes.
https://www.ford-trucks.com/forums/9...some-crap.html
It would be a good idea to get it fixed and save some worry.
johnfin1
Oct 19, 2014 01:42 PM
hazer
Jun 25, 2013 01:30 PM
CdnWillyG
Aug 11, 2012 09:13 PM
stever88
22
Jun 20, 2012 06:44 AM
black58
Jul 15, 2005 06:43 PM
