electric fuel pump?
Old Jun 25, 2010 | 10:53 PM
nwebbe1079's Avatar
nwebbe1079
electric fuel pump?
I've heard about relpacing or adding on an additional fuel pump like the holley red... my question(s) is do you bypass the ift pump or put it in before or after the lift pump? also which gph and psi rated pump is best. and finally which pump are good for diesel?
Old Jun 25, 2010 | 10:58 PM
GenLightening's Avatar
GenLightening
Bypass the stock unit, otherwise the diaphragm may rupture and fill your crankcase with fuel. Install the lift pump after, and as close to the selector valve as you can. The stock pump puts out about 4-7psi and 30gph.
As for the pumps, it's best to go with a diesel fuel rated unit ( I have the Facet Duralift in mine).
Old Jun 25, 2010 | 11:14 PM
nwebbe1079's Avatar
nwebbe1079
ok...does anybody have a diagram i could use? i think i understand but i learn better with pictures
Old Jun 26, 2010 | 12:48 AM
FORDF250HDXLT's Avatar
FORDF250HDXLT
heres info for the wiring:
Ford Truck Enthusiasts Forums - FORDF250HDXLT's Album: Garage - F250 - Picture
link to thread i mention there:
https://www.ford-trucks.com/forums/8...-terminal.html
the lift pump is located down on the passenger side of the engine.just unbolt it.then use a block off plate to cap it.
i used:
Mr.Gasket Fuel Pump Block Off Plate #5422
then you just connect the two fuel lines you just took off the pump together.
down on the drivers side frame rail is the FSV.you cant miss it.the fuel lines go into and out of it.
follow the line you just connected together down to it,and install the E-pump down there.ground it,and run your hot from the wire you just ran(learned in that thread above.)
im still using the low cost: Mr.Gasket Micro Electric Fuel Pump-Diesel 4-7psi 35GPH #12D
and it seems to be doing just fine.though i haven't even put 10k miles on my truck yet since purchased.but iv no complaints with it yet lol.
now you'll just turn the key and the ip will be fed fuel without cranking the engine,so leaks/air intrusion/no starting/hard starting due to any future events will be a thing of the past.pretty much your only concern is fixing future fuel leaks.but besides a mess,you'll be starting and running.
Old Jun 26, 2010 | 09:19 PM
nwebbe1079's Avatar
nwebbe1079
awesome thanks very much
Old Jun 26, 2010 | 09:31 PM
FORDF250HDXLT
your welcome.
there seems to be a mixed review of that cheap pump.i dunno,i think the key is to remove that small built in filter it has.i just went to auto zone,and showed them the pump hole and said i wanted a barbed fitting.keep clean fuel and change the fuel filter up top every 50k miles,and not run it out of fuel and it hopefully lasts.
if you want a nice one though,spend a few bucks and get a high quality carter pump.
im gunna keep running this to see what happens.im not scared lol.if she quits,ill have someone bring me another one to get home with.the mixed reviews have me worried enough that i wouldn't head out of state or anything without a backup pump.but i mainly work inside a 50 mile radius 99% of the time with this rig.
Old Jun 26, 2010 | 09:35 PM
nwebbe1079's Avatar
nwebbe1079
i dont drive this truck very far anyway mostly flat towing my friends off the trail and back home when they break their trucks. and a few scrap runs every month, how much did you pay for the pump if ya dont mind me askin?
Old Jun 26, 2010 | 09:38 PM
FORDF250HDXLT
i grabbed it off amazon.around 50 bucks.there's a 35$ one but it doesnt have seals made for diesel fuel supposedly.
Old Jun 26, 2010 | 09:40 PM
nwebbe1079's Avatar
nwebbe1079
also the Mr.Gasket Fuel Pump Block Off Plate #5422 is showing that its used for a big block chevy...is it still compatable?
nwebbe1079's Avatar
nwebbe1079
yea i saw that...
Old Jun 26, 2010 | 09:47 PM
FORDF250HDXLT
yeah it works for bb chevy.i prefer to call it a sb ford block off pump though as is fit those too......so said the package when it arrived anyway lol.makes me feel better calling it that.
lol.seriously tho.yup.that one does the trick.perfect seal.
Old Jun 26, 2010 | 09:50 PM
nwebbe1079's Avatar
nwebbe1079
ok cool. ill have to put up the video of me towin my buddies dodge 318 25 miles back to base...after i get my truck runnin, probably nxt weekend. 12 hour shifts suck when you have to wrench on stuff after work.
luv2ski
Apr 3, 2013 12:01 PM
Melody Guzman
Bio-diesel, Propane & Alternative Diesel Engine Fuels
Dec 22, 2012 08:38 PM
svtcobra041
31
Jan 9, 2010 06:41 AM
trike1946
Mar 13, 2005 06:40 AM
buckford
15
Sep 19, 2004 08:33 PM
