need hot terminal
any suggestions ? i have the pump wired to a manual switch for now, would like it hooked to turn on when key is in run.
GPs are manually switched,
thanx
Light green wire with red stripe behind the passenger side battery is the ignition circuit.
Use that wire for the trigger circuit.
The other option is the fuel shut off solenoid, front terminal drivers side of the IP.
is the relay needed when using the fuel shut off solenoid's hot?
So no matter where you tap into it at, you should use a relay and only use the FSS wire to trigger the relay.
The red/green ignition wire already powers several things under the hood, and the electric fuel pump may just increase the load enough to blow a fusible link at the wrong time.
So even though it works fine if you add the electric fuel pump, when the temp is below 32 degrees, it might add just enough load to blow a fusible link.
If your luck is like mine, it will happen at the worst time and location.
Battery positive terminal to fuse to relay positive power in terminal.
The relay power out terminal to the fuel pump.
Some of the ignition wires are red/yellow on the newer trucks.
so this is wrong then?
i want to run a line over from the + bat terminal into the fuse.then out from the fuse,to the + in of the relay.then with the other two wires,i want one to the pump,and the other to the fuel shut off solenoid right?
as it is now.it works.tho i guess its to no advantage lol oops.
iv got water in the lines and she's not starting.(frozen water) i blew the delivery line out,but the return is still blocked.
got my fuel selector valve hooked up correctly too,but the gauge isn't working.(it is sucking from the main tank with the switch on front tank.it will return to it too fine too,im sure,as i didnt cross those up.once i get the ice out.)
with it switched to the front tank,it draws from the front tank.and this tank is full.the gauge shows empty.
when i switch to the rear tank,it should suck from it fine,tho didn't check.but i know its not crossed with the delivery,so it must be right.the rear tank i plugged into R and front i plugged into L.
the gauge goes WAY over Full mark(a pretty much empty tank).
man what a time lol.
im getting it all ready so i can back under my new flatbed to put it on.hopefully all goes good tomorrow.
i followed post# 8 here.and all colors where same as my truck:
https://www.ford-trucks.com/forums/6...g-diagram.html
i dont really know if the gauges worked correctly before or not.i thought so tho.
The terminals should be labled.
30 – the power lead from the battery goes here (for the high amp device)
85 - this is the ground side of the coil… wire this to a chassis ground
86 - this is the power lead to actuate the relay coil (from the switch)
87 - this is the hi amp output to the device
To install this relay it would be wired like this.
Battery positive to fuse to relay terminal 30.
Relay terminal 87 to electric fuel pump positive lead.
Relay terminal 86 spliced into FSS wire.
Relay terminal 85 to ground.
If relay terminal 85 is not grounded, the trigger coil will not work to close the relay.
So no power will go to the electric pump.
Some of those small relays have a fifth terminal, 87A.
Those are SPDT (single pole double throw) relays.
On those relays the wiring is the same, except terminal 87 is hot when power is applied to terminal 86, terminal 87A is hot when no power is applied to terminal 86.
You have to be careful with relays with 5 terminals because what ever is on terminal 87A is on when everything should be off.
i think i may need new sending units.
thanks a mill.
