Sponsored by: Real Truck
Groan when starting off.
Old Jun 25, 2010 | 10:39 AM
GUNNERDOG's Avatar
GUNNERDOG
I park my truck in my driveway (see pic in sig) on a slope nose-high. After sitting for a few days it makes a groaning noise when drive it up and out of the driveway, but it goes away by the time i get to the end of the street... It is not a constant groan, it pulses, it groans once every tire rotation or so. This just started... any ideas what could be making a noise like that? It only happens after sitting for a few days, and i haven't experienced it on a flat-slope, only when i park it nose high. Noise sounds like it is coming from the back end somewhere.
Old Jun 25, 2010 | 10:47 AM
bpounds's Avatar
bpounds
Do you set the parking brake in your driveway? Maybe the brake shoes are dragging a little bit? I don't know if you have an auto or a manual, but you might try parking without the E-brake one time and see if it still makes the sound.
Old Jun 25, 2010 | 11:34 AM
GUNNERDOG's Avatar
GUNNERDOG
I never use the parking brake...the stupid thing barely works anyway. i back onto wheel chocks to take pressure off the parking pin and put it in park. Its an auto tranny.
Old Jun 25, 2010 | 06:57 PM
Fordfanatic4life's Avatar
Fordfanatic4life
could be a U-joint starting to dry out and wear...
Old Jun 25, 2010 | 09:25 PM
GUNNERDOG's Avatar
GUNNERDOG
maybe the driveshaft u-joint... hmmm. How would one go about checking that?
Old Jun 26, 2010 | 12:32 AM
redford's Avatar
redford
FTE Leadership Emeritus
Crawl under the truck, grab your driveshaft and try to spin it either direction, watching and feeling for play. If there is play in the U-joint it either needs to be replaced or will soon need to be replaced.
But, my thought was I would also check your front hubs. I guess the easiest way to check this is to lock them (without putting the truck in 4 wheel drive). If the groan doesn't occur then the hubs probably need servicing.
Old Jun 26, 2010 | 02:47 AM
cartmanea's Avatar
cartmanea
You can adjust your parking brake so it works better. It is supposed to self-adjust, but they usually stick and don't tighten automatically.
draboo
Oct 3, 2016 01:31 PM
fordf2501
Jun 1, 2016 08:22 PM
m350
Modular V8 (4.6L, 5.4L)
Nov 10, 2015 05:41 AM
bkuuz1
Nov 28, 2014 06:09 PM
