Major Break Lock UP
Old Jun 24, 2010 | 10:17 PM
greg97's Avatar
greg97
Major Break Lock UP
I have a 1975 F350 dump truck (hope to get some pics up soon) that had a major break lock up. We actually had to get a bobcat to lift the back end up and get me off the road cause I was blocking both lanes. Before the lock up I replaced both front break lines and got new front calipers (2 pistons). Bled and bled and bled them, dumped a load of top soil. Worked fine then BANG lock up. Pedal is rock hard, cracked front bleeder and it shot fluid over me. Could it be the poportioning valve? Any other ideas? Thanks for your help.
Old Jun 25, 2010 | 08:08 AM
greg97's Avatar
greg97
Anyone????????????? Help??????????
Old Jun 25, 2010 | 08:42 AM
mikeo0o0o0's Avatar
mikeo0o0o0
Was it only the front brakes that were locked up or were the rears locked also?
And if it was just the front was it one or both wheels?
After you cracked the bleeder did the brakes release?
If it was just one wheel I would suspect first the caliper or installation, second the hose. Even though both have been replaced a deffective part is always a possibility.
Both wheels, I would suspect the proportioning valve first, then, remote posibility the master cylinder.
If it was all wheels were locked about the only thing I could think of would be the master cylinder.
Old Jun 25, 2010 | 08:55 AM
Poison Oil Racing's Avatar
Poison Oil Racing
did you bled all 4 wheels or just the fronts? Maybe the proportioning valve got stuck based on only bleeding half of the system. I don't know about the dump trucks but on the pickups you are supposed to lock the proportioning valve in the OPEN position when you bleed the brakes.
What wheels actually locked up?
Dutter 2
1997 - 2003 F150
Oct 1, 2013 10:22 PM
fl-mitchells
16
Mar 15, 2013 01:43 PM
SNAFU_Bill
18
Feb 19, 2010 03:47 PM
bcschreib
1983 - 2012 Ranger & B-Series
Aug 19, 2006 03:56 PM
CLIFFDRISSEN
May 7, 2004 01:43 PM
