Rear breaks have more power then front breaks, and ABS code
So when i got this truck everything on the breaks were messed up. So long story short i gota new master cylinder new pads and all lines are bled. Now this hole time my ABS light has been on so i looked at all the sensors and i found one connector that gos to the rear axle but it has no where to plug into. But i also found some writing on the axle which tells me that is a different axle and may not have had ABS set up. But im not sure. Now the problem im having is when i hit the breaks i dont have much bite but if i push on them harder the rear will lock up and the front brakes are biting just a little like 50% power. So how can i get more stopping power to the front pads ? And if its that unconnected sensor is there anyway i can loop in out of the system ?.
dirty old brake fluid
good luck brother
Nah its ok I'd say the same thing if it was someone else. and I know they are fully bled. because my old fluid was dark brown and I bled tell I saw clear fluid and then bled out half a cups worth of break fluid and I did that to eatch caliper. they had a sale on break fluid so I bled it like crazy. and started at the furthest wheel. so Im perdy sure its fully bled but never hurts to do it again
Dutter 2
19
09-26-2014 10:13 AM
79shovelhead
10-16-2009 04:42 PM
351whitewindsor
1999 to 2016 Super Duty
08-09-2009 11:21 PM
