Radiator wont bolt up Help!!
Old Jun 24, 2010 | 07:51 PM
poppe's Avatar
poppe
Cool Radiator wont bolt up Help!!
I have what i know to be a 1977 f150 400 auto that i put a 79 or 78 grill and a rad support im not sure what it came off of . Anyways i went to put my 77 radiator in and the mount brackets that should be on the radiatior support arent there??? any ideas they are on the 77 rad support but that one is rotted on the mount.Does anybody know what the deal is short of cutting the brackets off of the old one and welding them on the 78/79?.thanks
Old Jun 24, 2010 | 08:14 PM
mikeo0o0o0's Avatar
mikeo0o0o0
Sounds like you have a rear mount radiator and a front mount support.
Old Jun 24, 2010 | 08:29 PM
poppe's Avatar
poppe
yea i did some research in the lmc catalog that seems to be the case. I found out you can use the 78/79 grill with a 77 rad support by bolting the 78 headlight buckets on the top and drilling out for the bottom and it will fit. Guess i will have to fix the rotted mount cause radiators arent cheap nor is it bad. So i guess i have an 78/79 radiator support in mint condition just painted gloss black if anyone is interested.
Old Jun 25, 2010 | 10:53 AM
dynamic's Avatar
dynamic
you could always find another rad in the salvage yard with good brackets!
Heat the solder from both tanks, and remove the brackets.
Re-solder the correct brackets onto the good tank. Spray bomb... and your good to go!
That is what I did for the SuperCooling Rad I found!
Old Jun 25, 2010 | 11:46 AM
poppe's Avatar
poppe
good idea but there are no junkyards around here with anything that old they junked everything pre 80 around here
Old Jun 25, 2010 | 11:49 AM
dynamic's Avatar
dynamic
What size rad do you have... I still have the front mount brackets from the SuperCooling rad!
Old Jun 27, 2010 | 05:40 PM
poppe's Avatar
poppe
i ended up cutting the brackets off the radiator and welding them on the other side and drill the slots a little wider and it fit right in about 2 hours.Not bad and only cost $2.00 ford bolts
Rory428
Nov 11, 2013 10:15 AM
Zues1
Jan 6, 2013 12:55 PM
barryf
Oct 11, 2011 07:27 PM
peganit2
Oct 15, 2008 11:24 PM
ghostflamed66
Jan 11, 2004 09:19 PM
