Radiator support questions
Old Nov 10, 2013 | 07:56 PM
Rory428's Avatar
Rory428
Are the radiator supports the same for 2WD and 4x4s? How about between the 73-77 round head light trucks and those 78 and 79s with rectangular head lights? I found a 78 F350 in a wrecking yard with what looks to be a virtually brand new rad support, but I am concerned that retaining my 74 F350s round head lights may be a problem. The wrecking yard looked it up on the computer, and said that the 73 thru 77 F series had a different rad support than a 78 & 79, but they don`t know what the differances may be. I don`t mind if its just a matter of drilling a few new holes,but I don`t want to get involved with a bunch of fabricating. Both the parts truck and mine are 2 WD dual rear wheel F350s, the 78 has a 400, my truck has a 390 (origionally a 360.) No A/C on either. Thanks.
Old Nov 11, 2013 | 12:19 AM
gpence's Avatar
gpence
I used a 78 core support on my 77. Had to drill new holes to mount my round head lights & such but it worked out fine.
Old Nov 11, 2013 | 04:31 AM
montana_highboy's Avatar
montana_highboy
Originally Posted by Rory428
Are the radiator supports the same for 2WD and 4x4s? How about between the 73-77.
They did change, when/how I couldn't tell you...
I've "retrofitted" front flange to reverse flange, you just need to be creative.
Old Nov 11, 2013 | 09:56 AM
Roger Carter's Avatar
Roger Carter
X2.
Radiator mounting might be different (6cyl, (small V8, big V8, etc.), so as Montana said you might need to be a bit creative.
Roger Carter
Old Nov 11, 2013 | 10:15 AM
gpence's Avatar
gpence
And assemble the grill first with the head light buckets attached. That way you know where to drill holes to mount them
poppe
Jun 27, 2010 05:40 PM
drunkenrich
Apr 7, 2010 06:02 AM
73FOMO
Jun 4, 2007 10:49 AM
tude
Nov 1, 2005 05:01 AM
Redj
Jan 7, 2004 08:40 AM
