Radiator Support
Old Dec 21, 2012 | 10:10 AM
Zues1's Avatar
Zues1
Radiator Support
Gents, I picked up a radiator support I thought would fit my 1973 f100.
Turns out it's a bit different. The 1973 has 4 headlight bracket mounting holes like the one in this ebay link.
The one I bought looks very similar but only has 2 headlight bracket mounting holes in the center area. A couple of the other mounting holes are off a bit.
Any idea what year/model this support fits?
Rad Core Support Radiator Ford Truck 73 79 F100 F150 F250 F350 77FT5 2F | eBay
Old Dec 21, 2012 | 10:42 AM
HIO Silver's Avatar
HIO Silver
Could it be for a 78-79 with square headlights?
Old Dec 21, 2012 | 10:48 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
1973/79 F100/350: There are THREE different radiator supports!
D8TZ-16138-A .. Radiator Support-Use with rectangular headlamps: 1978/79 F100/350 & Bronco.
Has 2 sets of mounting holes: 23" between centers, 28 1/2" between centers.
The area behind the headlamp buckets is dished inwards to allow the rectangular buckets to fit correctly.
1973/79 F100/350 with round headlamps: There are TWO different radiator supports!
D3TZ-16138-B .. Radiator Support-28 1/2" between radiator mounting holes.
D3TZ-16138-D .. Radiator Support ~ 2 sets of mounting holes: 23" between centers, 25 1/2" between centers.
The optional Super Cooling Radiator is higher than the Standard, Xtra Cooling & A/C radiators, so its specific radiator support has a larger opening radius.
Super Cooling Radiator measures: 26 1/4" wide x 24 1/8" high // Standard/Xtra Cooling/A/C radiators measure: 26 1/4" wide x 19 3/4" high.
Old Dec 21, 2012 | 11:49 AM
gpence's Avatar
gpence
[ url=http://www.ebay.com/itm/RAD-core-SUPPORT-Radiator-Ford-Truck-73-79-f100-f150-f250-f350-77FT5-2F-/230898853764?fits=Model:F-100&hash=item35c2a4e784&item=230898853764&pt=Vinta ge_Car_Truck_Parts_Accessories&vxp=mtr]Rad Core Support Radiator Ford Truck 73 79 F100 F150 F250 F350 77FT5 2F | eBay[/url]
Put your grill, inserts & head light buckets all together then put a couple bolts in to hold the grill to the core support Mark where you need to drill the hole for the head light buckets real good pull the grill back off drill your holes & bam good to go.
Old Jan 6, 2013 | 12:52 PM
Zues1's Avatar
Zues1
Numberdummy, thanks for the info. I did manage to find a number stamped in the top of the support. 16139 BA. Is this a number you reconize?
Old Jan 6, 2013 | 12:55 PM
Zues1's Avatar
Zues1
Numberdummy, I found this number stamped in the top of the support. 16139BA, do you reconize this number?
TheDudeAbides
WTB - Parts & other
Feb 25, 2014 05:52 PM
65f100CoryE.
Jan 28, 2010 04:42 AM
73FOMO
Jun 4, 2007 10:49 AM
tude
Nov 1, 2005 05:01 AM
Redj
Jan 7, 2004 08:40 AM
