AC Compressor
Old Jun 24, 2010 | 12:40 AM
Mike Bartlett's Avatar
Mike Bartlett
AC Compressor
Hi All,<?xml:namespace prefix = o ns = "urn:schemas-microsoft-comfficeffice" /><o></o>
<o> </o>
My Ac Compressor cycles on then off about every 10 seconds. I can see the clutch kick on for about 10sec then it goes off for about 10sec. Will do this cycle continuously. Of course all I get out the vents is hot air. There is a small amount of oil that appears to be seeping from the rear hose I assume an o-ring issue. My assumption is I am out of Freon but will that cause the compressor to cycle like this? I guess I'll have to bring to in to someone for repair but would like to get an idea of what's wrong prior to that. <o></o>
<o> </o>
1995 F350 Crew Cab Dually 7.3DI Auto 105K-Miles<o></o>
<o></o>
Thanks for your help...<o></o>
<o></o>
Mike
Old Jun 24, 2010 | 12:49 AM
chicagodragon's Avatar
chicagodragon
the oil seepage will indicate a leak. 10 sec sounds likke a normal cycle. before you jump to a expensive shop, make sure the blend door is not shutting on you. can you get gauges on it and post back with readings? even the cheapie from autozone that comes with the can will give us a hint.
Old Jun 24, 2010 | 12:52 AM
MustangMatt96GT's Avatar
MustangMatt96GT
being low or out of freon will make a compressor cycle. it should be cycling every couple of mintues... sounds like you need to recharge it and find the leak, and then fix it, and recharge again.
Old Jun 24, 2010 | 12:56 AM
Mike Bartlett
Thanks guys for the quick help. It sounds like a somewhat simple fix? I was hoping I didn't need a compressor. I'll posty back what I find.
Thanks again,
Mike
Old Jun 24, 2010 | 12:58 AM
chicagodragon
get readings first, then recharge. if there is a leak, recharge with the UV type so you can pin point the leak with a black light.
Old Jun 24, 2010 | 01:06 AM
Mike Bartlett
Well I have never done much with AC's before but have worked on most every other part of a car/truck so I am willing to try. If I buy a set of guages how do I hook them up or would it be better I just bring it in?
Mike
Old Jun 24, 2010 | 01:11 AM
chicagodragon
alot cheaper if you do it yourself and post to us. dont just dump a bunch of freon in hoping for the best. sometimes it is just a sensor and not a real prob. but once you get a set of gauges, we can talk you through the rest. if anything, get the cheapie from autozone and get back with us.
Old Jun 24, 2010 | 01:20 AM
Mike Bartlett
Will do.
Thanks...
Old Jun 24, 2010 | 08:02 AM
jeep1947's Avatar
jeep1947
Get a set of inexpensive gages at Harbor Freight. I got a set last month for 39.00 makes checking things a bunch easier. Good luck and post back to let us know.
Old Jun 27, 2010 | 12:03 AM
Mike Bartlett
Sorry guys but I probably will not being fixing the AC myself. I had a hell of a time reinstalling the banjo bolt under the turbo in an attempt to repair a fuel leak. I spent two days trying to get the nut back on with new bushings but just couldn't get it to start threading. I had it towed to the dealer today and will probably have them fix the AC while its there. Damn, I hate to get beat by things like this.
Anyway, thanks for the advice. I had gone out and bought cheap guages/freon but never got to the AC problem.
Thank again,
Mike
closetheborder
Aug 16, 2012 11:40 AM
Leichardti
22
Jan 9, 2012 03:27 AM
smkf100
Oct 12, 2011 04:29 PM
redwingbd
Jul 28, 2011 12:05 AM
Mike821
Feb 16, 2011 10:20 AM
